14-4K-Touch-Monitor
1. Introduction​
The 14inch portable monitor features a 3840 × 2160 Ultra HD resolution IPS panel with 100% sRGB color gamut, delivering sharp image quality and vivid, accurate colors. With a 178° ultra-wide viewing angle, it ensures consistent visuals from different perspectives. The display supports 10-point capacitive touch with responsive multi-touch operation. It is equipped with standard 75 mm M4 VESA mounting holes, allowing flexible installation and space optimization. Compatible with various standard HDMI devices, it is suitable for a wide range of application scenarios.
2. Product Specifications​
ItemDescriptionUnit
Model14-4K-Touch-Monitor/
Size14Inch
Viewing Angle178Deg
Resolution3840 × 2160Pixels
Product Dimensions322.51 (H) × 191.85 (V)mm
Active Area309.71 (H) × 174.39 (V)mm
Color Gamut100%sRGB
Brightness400cd/m²
Contrast Ratio1500:1/
Backlight ControlOSD menu adjustment/
Refresh Rate60Hz
Display InterfaceMini HDMI / Type-C/
Power Input5V
Power Consumption9.6W
3. Interface Description​
4. Menu Button Description​
4.1 Button Functions​
  • Scroll up: Adjust volume
Power Button
  • Short press (outside menu): Open input source selection panel (Auto / Type-C / HDMI)
  • Short press (inside menu): Exit menu interface
  • Long press: Turn backlight on/off
🔴 **Note: **Normally, the screen will automatically turn on when a valid signal is detected after power on, no manual button press required.
4.2 OSD Main Menu Overview​
  • Pressing down the rotary knob enters the OSD main menu, where you can adjust the following:
5. Using with Raspberry Pi​
5.1 Software Configuration​
  1. Connect the TF card to your computer.
  2. Download and install the Raspberry Pi Imager from the official Raspberry Pi website.
  4. Preconfigure the system by pressing CTRL+SHIFT+X (or clicking the gear icon in the bottom right corner). Save the settings.
hdmi_force_hotplug=1
hdmi_enable_4kp60=1
  1. Insert the TF card into the Raspberry Pi.
5.2 Hardware Connection​
  1. Connect the 20W PD power adapter to the power port of the LCD.
  2. Use a Type-C cable to connect the Raspberry Pi to the display’s one-cable (Type-C) interface.
  3. Connect the HDMI interface of the LCD to the HDMI interface of the Raspberry Pi, power on the Raspberry Pi. After waiting for a few seconds, the LCD will display and touch normally.
6. Using with PC​
Supports PC version of Windows 11 / 10 / 8.1 / 8 / 7 system.
  2. Connect the Type-C cable to the PC and the touch port of the LCD.
  3. Connect the HDMI interface of the LCD to the HDMI interface of the PC. After waiting for a few seconds, the LCD will display and touch normally.
7. Using with One-Cable Connection Devices​
  2. Connect the full-function Type-C interface of the LCD to the Type-C interface of the device. Wait for a while and it will display normally.
8. Dimensions​
