14-Portable-Monitor
1. Introduction​
The 14″ Portable Monitor features a 1920×1200 IPS panel with 100% sRGB color gamut and supports an ultra-wide 178° viewing angle. It comes with 75mm fixed M4 VESA mounting holes, saving installation space, and is compatible with most standard HDMI devices, making it suitable for various applications.
2. Product Specifications​
ItemDescriptionUnit
Model14″ Portable Monitor/
Size14Inch
Viewing Angle178Deg
Resolution1920×1200Pixels
Dimensions311.43(H)×217.13(V)mm
Display Area301.60(V)×188.50(H)mm
Color Gamut100%sRGB
Max Brightness300cd/m²
Contrast1500:1/
Backlight Adj.OSD Menu/
Refresh Rate60Hz
Power input5V/
Power Consumption4.6Watt
3.Interface​
4. Menu Button Description​
4.1 Button Functions​
  • Scroll up: Adjust volume
Power Button
  • Short press (outside menu): Open input source selection panel (Auto / Type-C / HDMI)
  • Short press (inside menu): Exit menu interface
  • Long press: Turn backlight on/off
🔴 **Note: **Normally, the screen will automatically turn on when a valid signal is detected after power on, no manual button press required.
4.2 OSD Main Menu Overview​
  • Pressing down the rotary knob enters the OSD main menu, where you can adjust the following:
5. Using with Raspberry Pi​
5.1 Software Configuration​
  1. Connect the TF card to your computer.
  2. Download and install the Raspberry Pi Imager from the official Raspberry Pi website.
  4. Preconfigure the system by pressing CTRL+SHIFT+X (or clicking the gear icon in the bottom right corner). Save the settings.
hdmi_mode=87
hdmi_force_hotplug=1
config_hdmi_boost=10
hdmi_timings=1920 0 48 32 80 1200 0 3 6 26 0 0 0 60 0 154000000 0
  1. Insert the TF card into the Raspberry Pi.
5.2 Hardware connection​
  1. Connect the Type-C port of the LCD to the USB port of the Raspberry Pi.
  2. Connect the HDMI port of the LCD to the HDMI port of the Raspberry Pi, power on the Raspberry Pi, wait for a while, and it will display normally.
6. Using with PC​
Supports Windows 11 / 10 / 8.1 / 8 / 7 systems.
  1. Connect the Type-C interface of the LCD to the USB interface of the PC.
  2. Connect the HDMI interface of the LCD to the HDMI interface of the PC, wait for a while, and it will display normally.
Note: If the PC's USB port is aging and provides insufficient power, try using the rear USB ports or an external 5V 3A power adapter.
7. Using with One-Cable Connection Device​
Connect the full-function Type-C port of the LCD to the Type-C port of the device. Wait for a while and it will display normally.
**Note: Your device model must support full-function Type-C wired projection to use the Type-C display function. **
8. Dimensions​
