15.6-Portable-Monitor
1. Introduction​
The 15.6″ Portable Monitor features a 1920×1080 IPS panel with 100% sRGB color gamut and supports an ultra-wide 178° viewing angle. It comes with 75mm fixed M4 VESA mounting holes, saving installation space, and is compatible with most standard HDMI devices, making it suitable for various applications.
2. Product Specifications​
ItemDescriptionUnit
Model15.6″ Portable Monitor/
Size15.6Inch
Viewing Angle178Deg
Resolution1920×1080Pixels
Dimensions355.51 (H) × 221.47 (V)mm
Display Area344.16 (H) × 193.59 (V)mm
Color Gamut100%sRGB
Max Brightness300cd/m²
Contrast1000:1/
Backlight Adj.OSD Menu/
Refresh Rate60Hz
Power input5V/
Power Consumption6.3Watt
3.Interface​
4. Menu Button Description​
4.1 Button Functions​
  • Scroll up: Adjust volume
Power Button
  • Short press (outside menu): Open input source selection panel (Auto / Type-C / HDMI)
  • Short press (inside menu): Exit menu interface
  • Long press: Turn backlight on/off
🔴Note: Normally, the screen will automatically turn on when a valid signal is detected after power on, no manual button press required.
4.2 OSD Main Menu Overview​
  • Pressing down the rotary knob enters the OSD main menu, where you can adjust the following:
5. Using with Raspberry Pi​
5.1 Software Configuration​
  1. Connect the TF card to your computer.
  2. Download and install the Raspberry Pi Imager from the official Raspberry Pi website.
  4. Preconfigure the system by pressing CTRL+SHIFT+X (or clicking the gear icon in the bottom right corner). Save the settings.
hdmi_mode=82
hdmi_cvt 1920 1080 60 6 0 0 0
  1. Insert the TF card into the Raspberry Pi.
5.2 Hardware Connection​
  1. Connect the 5V 3A power adapter to the power port of the LCD.
  2. Connect the HDMI interface of the LCD to the HDMI interface of the Raspberry Pi, power on the Raspberry Pi. After waiting for a few seconds, the LCD will display normally.
6. Using with PC​
Supports PC version of Windows 11 / 10 / 8.1 / 8 / 7 system.
  2. Connect the HDMI interface of the LCD to the HDMI interface of the PC. After waiting for a few seconds, the LCD will display normally.
7. Using with One-Cable Connection Devices​
  2. Connect the full-function Type-C interface of the LCD to the Type-C interface of the device. Wait for a while and it will display normally.
8. Dimensions​
