24.5-2K-Portable-Monitor
1. Introduction​
​ The 24.5″ portable monitor features a 2560x1440 resolution IPS panel with 100% sRGB wide color gamut, supporting a 178° ultra-wide viewing angle and up to a 165Hz refresh rate. It comes with 75mm fixed M4 VESA mounting holes and a foldable stand to save installation space. Compatible with most standard HDMI devices, it suits a wide range of application needs.
2. Product Specifications​
ItemDescriptionUnit
Model24.5-2K-Portable-Monitor/
Size24.5Inch
Viewing Angle178Deg
Resolution2560x1440Pixels
Dimensions561.60 (H) × 324.57 (V)mm
Display Area541.44 (H) × 302.62 (V)mm
Color Gamut100%sRGB
Brightness300cd/m²
Contrast Ratio1000:1/
Backlight Adj.OSD Menu Adjustment/
Refresh Rate165Hz
Power InputUSB-C (PD 20V⎓1200mA)/
Power Consumption24.5Watt
3.Interface and Button Function Descriptions​
4. Using with Raspberry Pi​
4.1 Software Configuration​
Supports Raspberry Pi OS / Ubuntu / Kali / Retropie systems.
  1. Connect the TF card to your PC.
  2. Download and install Raspberry Pi Imager from the official Raspberry Pi website.
  4. Configure the system in advance by pressing CTRL+SHIFT+X (or clicking the gear icon in the lower-right corner), then save your settings.
    hdmi_force_hotplug=1
    hdmi_mode=87
    hdmi_timings=2560 0 48 32 80 1440 0 3 5 60 0 0 0 60 0 241500000 3
    hdmi_drive=2
    config_hdmi_boost=10
    Note: The actual output resolution depends on the performance of the main controller. On devices such as Raspberry Pi 3 and Zero, the default maximum resolution is 1080P@60Hz.
  7. Insert the TF card into the Raspberry Pi.
4.2 Hardware Connection​
  1. Connect the 65W power adapter to the LCD’s power port.
  2. Connect the LCD's HDMI port to the Raspberry Pi's HDMI port. Power on the Raspberry Pi. After a few seconds, the display should work normally.
5. Using with a PC​
Supports Windows 11 / 10 / 8.1 / 8 / 7 operating systems.
  2. Connect the HDMI interface of the LCD to the HDMI interface of the Raspberry Pi, power on the Raspberry Pi. After waiting for a few seconds, the LCD will display normally.
6. Using with One-Cable Connection Devices​
  2. Connect the full-function Type-C interface of the LCD to the Type-C interface of the device. Wait for a while and it will display normally.
7. Dimensions​
