3.5-RPi-LCD-CTP
1. Introduction​
The 3.5-RPi-LCD-CTP is a touch display module that communicates via SPI and I2C interfaces. It features the ST7796S display driver and GT911 touch controller, offering a 320×480 resolution, IPS high-brightness display, and responsive capacitive touch. It combines stability with visual appeal.
2. Product Specifications​
📋 Specification Table​
ItemDescription
Model3.5-RPi-LCD-CTP
Cover Size61.00 (H) × 92.44 (V) mm
Display Area49.36 (H) × 73.84 (V) mm
Resolution320 (H) x 480 (V)
Panel TypeIPS
Touch TypeCapacitive
Viewing Angle170°
Color Gamut65% NTSC
Brightness200cd/m²
Contrast Ratio1000:1
Backlight ControlPWM imming
Refresh Rate60Hz
Power Consumption0.8W
Power Supply Voltage5V
Logic Voltage3.3V
InterfacesDisplay:SPI
Touch:I2C
Controller ICsDisplay:ST7796S
Touch:GT911
3. Pin Definition​
Pin NumberLabelDescription
1NCNo connection
2, 45VPower supply (5V)
3TP_SDATouch I2C data pin
5TP_SCLTouch I2C clock pin
6, 9, 14, 20, 25GNDGround
7TP_INTTouch interrupt pin
11TP_RSTTouch reset pin (active low)
12LCD_PWMBacklight PWM control pin
13LCD_RSTDisplay reset pin (active low)
15LCD_DCData/Command control pin (high for data, low for command)
19MOSISPI Master Out / Slave In
21MISOSPI Master In / Slave Out
23SCLKSPI Clock
24CE0SPI Chip Select (active low)
16–18, 8, 10, 22, 26NCNo connection
4. Product Dimensions​
5. Hardware Connection​
  1. Align and connect the module's 26-pin female header to the Raspberry Pi's 40-pin GPIO header.
  2. It is recommended to use copper standoffs for secure mounting to prevent looseness.
6. Software Setup​
6.1. Enable SPI and I2C Interfaces​
Open the terminal and execute the following commands to enable the required interfaces:
sudo raspi-config nonint do_spi 0
sudo raspi-config nonint do_i2c 0
6.2 Install Dependencies​
sudo apt-get install python3-pip
sudo apt-get install python3-pil
sudo apt-get install python3-numpy
sudo apt-get install python3-spidev
sudo apt install python3-smbus2
6.3 Example Program​
wget https://files.luckfox.com/wiki/Luckfox/Display/3inch5-RPi-LCD-CTP/3inch5-RPi-LCD-CTP-RPI-Demo.zip
unzip 3inch5-RPi-LCD-CTP-RPI-Demo.zip
cd 3inch5-RPi-LCD-CTP-RPI-Demo
sudo python ./main.py
7. Desktop Display Configuration for Bookworm System​
wget https://files.luckfox.com/wiki/Luckfox/Display/3inch5-RPi-LCD-CTP/St7796s.zip
unzip St7796s.zip
sudo cp st7796s.bin /lib/firmware/
Edit config.txt:
sudo nano /boot/firmware/config.txt
Add the following lines at the end of the [all] section:
dtparam=spi=on
dtoverlay=mipi-dbi-spi,speed=48000000
dtparam=compatible=st7796s\0panel-mipi-dbi-spi
dtparam=width=320,height=480,width-mm=49,height-mm=79
dtparam=reset-gpio=27,dc-gpio=22,backlight-gpio=18
dtoverlay=goodix,addr=0x5d
To apply changes, reboot:
sudo reboot
Method 2: Install Kernel Module and DTBO Driver​
📌 Note: Bookworm system requires the official kernel version 6.6.51 or higher.
Install Driver Module​
  1. Check the current kernel version:
uname -a
Sample output (Raspberry Pi 5):
Linux raspberrypi 6.12.47+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1 (2025-09-16) aarch64 GNU/Linux
Explanation:
  • Kernel Version: 6.12.47+rpt-rpi-2712
  • Architecture: 64bit ARM(AArch64)
  1. Download and install the st7796 driver module:
# Download and unzip driver files
wget https://files.luckfox.com/wiki/Luckfox/Display/3inch5-RPi-LCD-CTP/Luckfox-st7796s.zip
unzip Luckfox-st7796s.zip
cd Luckfox-st7796s
# Enter the folder for the corresponding kernel version (as in the example)
cd 6.12.47/64/rpi-2712-RPi5
# Copy the kernel module
sudo cp st7796s.ko /lib/modules/$(uname -r)/kernel/drivers
# Add the module to auto-load on boot
sudo nano /etc/modules
# Add the following line at the end of the file:
st7796s
As shown below:
Resolve kernel module dependencies:
sudo depmod -a
  1. Configure the device tree overlay:
cd
wget https://files.luckfox.com/wiki/Luckfox/Display/3inch5-RPi-LCD-CTP/Luckfox35CTP.dtbo
sudo cp Luckfox35CTP.dtbo /boot/overlays/
For RPi4 & RPi5​
  1. Follow the steps above to install the driver module
  2. Edit the config.txt file:
Comment out dual-screen related configurations.
Add the following lines at the end of the**[all]**section:
dtparam=i2c_arm=on
dtparam=i2c_arm_baudrate=50000
dtparam=spi=on
dtoverlay=Luckfox35CTP,fps=60,speed=48000000,rotate=90,ts_rotate_90
hdmi_force_hotplug=1
max_usb_current=1
hdmi_mode=87
hdmi_cvt 480 320 60 6 0 0 0
hdmi_drive=2
  1. Create X11 Configuration File
sudo nano /etc/X11/xorg.conf.d/98-spi-screen.conf
Add the following content:
Section "Device"
Identifier "SPI Screen"
Driver "fbdev"
Option "fbdev" "/dev/fb0"
EndSection
🔧 After completing the entire process, if there is no display, try changing /dev/fb0 to /dev/fb1 and rebooting.
  1. Switch to the X11 Display System
sudo raspi-config nonint do_wayland W1
sudo reboot
For All Raspberry Pi Versions (Requires Bookworm Lite)​
⚠️ Only applicable to the following versions:
64bit Lite
32bit Lite
  1. Edit the config.txt File
Comment out KMS and dual-display settings.
At the end of the [all] section, add the following lines:
dtparam=i2c_arm=on
dtparam=spi=on
max_usb_current=1
hdmi_mode=87
hdmi_drive=2
  1. Install Required Software
# X11 Services
sudo apt-get install --no-install-recommends xserver-xorg -y
sudo apt-get install --no-install-recommends xinit -y
# Desktop Manager and GUI
sudo apt install lightdm -y
sudo apt install raspberrypi-ui-mods -y
# Git and Browser (Optional)
sudo apt install git -y
sudo apt install chromium-browser -y
# VLC Media Player (Optional)
sudo apt install vlc -y
  1. Download and Run the Driver
sudo apt install libraspberrypi-dev -y
sudo apt-get install unzip -y
sudo apt-get install cmake -y
# Download and build fbcp
sudo wget https://files.luckfox.com/wiki/Luckfox/Display/3inch5-RPi-LCD-CTP/Rpi-fbcp.zip
sudo unzip ./Rpi-fbcp.zip
cd rpi-fbcp/
sudo rm -rf build
sudo mkdir -m 777 ./build
cd ./build
sudo cmake ..
sudo make -j4
sudo install fbcp /usr/local/bin/fbcp
  1. Configure Auto-Start for startx and fbcp
  • Edit the Bash Shell file:
sudo nano ~/.bashrc
Add the following to the end of the file:
if [ "$(cat /proc/device-tree/model | cut -d ' ' -f 3)" = "5" ]; then
# Configuration for RPi 5B
export FRAMEBUFFER=/dev/fb1
startx 2> /tmp/xorg_errors
else
# Configuration for non-RPi 5
export FRAMEBUFFER=/dev/fb0
fi
  • Create fbcp systemd Service
sudo nano /etc/systemd/system/fbcp.service
[Unit]
Description=Framebuffer Copy for Raspberry Pi
After=network.target
[Service]
ExecStartPre=/bin/sleep 20
ExecStart=/usr/local/bin/fbcp
Restart=always
User=root
Group=root
[Install]
WantedBy=multi-user.target
Then execute the following commands:
sudo systemctl daemon-reload
sudo systemctl enable fbcp.service
sudo systemctl start fbcp.service
  1. Enable CLI Auto-login
sudo raspi-config nonint do_boot_behaviour B2
sudo reboot
Notes
⚠️ The username must be pi, otherwise auto-login will not work properly.
🚀 Each reboot will result in a longer startup time, and SSH availability will be delayed accordingly.
8. Screen Rotation Settings​
GUI Rotation​
  1. Open the Screen Configuration application
  2. Check "Touchscreen"
  3. Go to Orientation and select the desired rotation angle.
Command Line Rotation​
💡 It is recommended to use this command in the Wayland environment. Applicable to Raspberry Pi OS Bookworm and above.
  1. Install the 'wlr-randr'' tool:
sudo apt install wlr-randr
  1. View available output names:
wlr-randr
Sample output (e.g., SPI-1):
  1. Execute the rotation command:
wlr-randr --output SPI-1 --transform 90
📝 Supported rotation parameters:
normal
90
180
270
9. Adjust the backlight​
PWM dimming​
  • Install WiringPi
cd ~
git clone https://github.com/WiringPi/WiringPi.git
cd WiringPi
./build
gpio -v
A successful installation will output the gpio version as shown below:
  • Manually adjust the display PWM backlight
gpio -g mode 18 pwm # Occupied pins are PWM pins
gpio pwmc 100 # Set PWM clock divider
gpio -g pwm 18 0 # Darkest
gpio -g pwm 18 1023 # Brightest
gpio -g mode 18 out # Release as output
Pinctrl dimming​
  • Set bright screen
sudo pinctrl set 18 op dh
  • Set the screen off
sudo pinctrl set 18 op dl
10. Resources​
Downloads
Choose your preferred download source.
GitHubGoogle Drive
DownloadDownload
Available Resources
ResourceDirectoryDescription
📖 User ManualDocs/Product documentation and user guide.
💻 Demo CodeCode/Demo applications and source code for Raspberry Pi.
📑 SchematicSchematic/Hardware schematic in PDF format.
📄 DatasheetsDocs/datasheets/Datasheets for the display driver IC and touch controller.
📐 CAD DrawingsCAD/2D mechanical drawings in DXF/PDF format.
🧩 3D Models3D Models/STEP models for mechanical and enclosure design.
