Install an operating System
1. Preparation​
  • Luckfox-Lume board
  • USB Type-A to Type-C data cable
  • 100M/1000M Ethernet cable and router
  • USB-to-TTL module
Tip
The default baud rate of Luckfox-Lume is 115200. It is recommended to use serial modules such as CH343, FT232, or CP2102.
2. Driver Installation​
  1. Download the Allwinner flashing tool PhoenixSuit.
  2. Open the PhoenixSuit\Drivers\AW_Driver folder and install the driver by running InstallUSBDrv.exe. Restart your computer after installation.
  3. After successful installation, the device will appear in Device Manager.
3. Image Download​
Luckfox-Lume supports Buildroot images. Users can download the appropriate image based on their requirements.
Image naming convention: (Board Model) - (System) - (Storage Medium) - (Release Date)
  • Board Model: Luckfox-Lume
  • System: Buildroot
  • Storage Medium: SPI NAND Flash
VersionDescriptionDownload
BuildrootImage for SPI NAND FLASH and TF cardGoogle Drive Download Link
4. Image Flashing (Windows)​
4.1 SPI NAND FLASH​
  1. Open PhoenixSuit.exe and load the image file to be flashed.
  2. If the board was already connected to the computer during driver installation, disconnect it first.
  3. Press and hold the FEL button on the board, then connect the board to the computer. A prompt window will appear. Click YES to start flashing.
TIP
Even though the board is connected, PhoenixSuit may still display "No device detected" in the lower-left corner. This is normal behavior and differs from how Rockchip devices are recognized in MaskROM mode.
  1. A successful installation will be shown as:
4.2 TF Card​
  1. Open the boot card creation tool PhoenixCard.exe.
  2. Insert the TF card into the Windows computer through a card reader. Select the sdboot image file, choose Startup Card mode, and click Burn to create the boot card.
  3. After the boot card is created, insert the TF card into the development board and power on the board. The board will boot from the TF card first. When the boot0 log prints card no is 0, the system has booted from the TF card.
