Getting Started
1. Connect and Start the Device​
  1. Install the PLC in a suitable location and power it through PoE, USB-C (5 V), or the power terminal (DC 7-24 V wide-range input).
  2. Connect either Ethernet port to the LAN with a network cable. On first startup, the network uses DHCP to obtain an IP address by default.
  3. Wait for Luckfox Lyra PLC to finish booting, then access the device using the IP address shown on the LCD.
Note
http://192.168.9.187/ is the address of the preview device used while preparing this documentation. It is not a fixed factory address for every PLC.
2. Complete the Initial Setup​
  1. Enter the PLC IP address in a browser, for example http://192.168.9.187/.
  2. On first access, choose an authentication mode on the initial setup page.
  3. Password protection is recommended. Set a password of at least 8 characters and store it securely.
  4. After completing the setup and signing in to the PLC WebUI, open the Overview page to view system resources and network interface status.
warning
No-password mode allows anyone who can reach the WebUI to operate the PLC. Do not use it on an untrusted network or for remote access.
