Luckfox Pico Pi
Product Introduction
The Luckfox Pico Pi series includes the Pi A, Pi A W, Pi B, and Pi B W. All four models share the same interface layout but differ in SoC, memory capacity, and wireless connectivity:
- Luckfox Pico Pi A / Pi A W use the RV1106G3 with 256 MB DDR3L and a 1 TOPS NPU.
- Luckfox Pico Pi B / Pi B W use the RV1106G2 with 128 MB DDR3L and a 0.5 TOPS NPU.
- Models with the W suffix provide 2.4 GHz Wi-Fi 6, Bluetooth 5.2, and BLE connectivity.
The series includes 8 GB eMMC storage, a 2-lane MIPI CSI camera interface, 100 Mbps Ethernet, IEEE 802.3af PoE, audio input and output, USB Device, four USB 2.0 Host ports through a hub, and a 40-pin expansion header compatible with the Raspberry Pi layout. The onboard M.2 and Nano SIM slots support 4G modules such as the SIM7600G-H-M.2. The MicroSD card slot is for storage expansion and does not support system boot. All models are supported by the Buildroot system and SDK.
| Luckfox Pico Pi A | Luckfox Pico Pi A W | Luckfox Pico Pi B | Luckfox Pico Pi B W | |
| SOC | RV1106G3 | RV1106G2 | ||
| Processor | Cortex A7 1.2GHz | |||
| NPU | 1 TOPS, supports INT4, INT8, and INT16 | 0.5 TOPS, supports INT4, INT8, and INT16 | ||
| VEPU | Supports H264/H265 video encoding | |||
| ISP | Maximum 5M @30fps input | |||
| Memory | 256MB DDR3L | 128MB DDR3L | ||
| Wi-Fi+Bluetooth | / | 2.4GHz WiFi6 Bluetooth 5.2/BLE | / | 2.4GHz WiFi6 Bluetooth 5.2/BLE |
| Default Storage | eMMC(8GB) | |||
| POE Port | IEEE 802.3af PoE | |||
| Ethernet | 10/100M Ethernet controller and embedded PHY | |||
| Camera Interface | 1 x MIPI CSI 2-lane | |||
| Audio | 1 x Surface-mount microphone 1 x Microphone expansion port (MX1.25mm-2P) 1 x 3.5mm audio output | |||
| USB | 1 x USB Device 4 x USB HOST 2.0 (HUB expansion) | |||
| RTC | 1 x RTC Port(SH1.0-2P) | |||
| Storage Expansion | 1 x MicroSD slot (storage-only, no system boot support) | |||
| Mobile Connectivity | 1 x Nano SIM slot 1 x 4G module M.2 slot (supports SIM7600G-H-M.2 4G module) | |||
| GPIO | Based on Raspberry Pi 40Pinout | |||
