SIM7600G-H M.2
1. Introduction​
The SIM7600G-H-M.2 is an LTE Cat 4 module compatible with LTE-TDD, LTE-FDD, HSPA+, GSM, GPRS, and EDGE standards, providing up to 150 Mbps downlink and 50 Mbps uplink rates. The module adopts the M.2 form factor, consisting of the SIM7600G-H module and an M.2 adapter board for easier integration.
The SIM7600G-H-M.2 series integrates multiple high-precision GNSS positioning systems, comes with built-in network protocols, and supports USB drivers and software functions on mainstream operating systems such as Windows, Linux, and Android. It is also AT command compatible, supporting features of the SIM7500/SIM7600 series modules.
2. Features​
  • Standard M.2 B KEY interface, strong compatibility
  • Multi-constellation high-precision GNSS receiver support
  • Global coverage for LTE, UMTS, and GSM networks
  • Rich software features: FOTA, LBS, TLS
  • AT command compatible with SIM7500/SIM7600 series modules
Note
Difference between B Key and M Key:
SIM7600G-H
3. Specifications​
Operating Bands
LTE-FDDB1, B2, B3, B4, B5, B7, B8, B12, B13, B18, B19, B20, B25, B26, B28, B66
LTE-TDDB34, B38, B39, B40, B41
WCDMAB1, B2, B4, B5, B6, B8, B19
GSM850, 900, 1800, 1900 MHz
GNSSGPS, Beidou, GLONASS, GALILEO, QZSS
Data Transmission
LTE150 Mbps (DL) / 50 Mbps (UL)
HSPA+42 Mbps (DL) / 5.76 Mbps (UL)
WCDMA384 Kbps (DL) / 384 Kbps (UL)
EDGE236.8 Kbps (DL) / 236.8 Kbps (UL)
GPRS85.6 Kbps (DL) / 85.6 Kbps (UL)
Software Features
Operating SystemWindows/Linux/Android
ProtocolsTCP, IP, IPV4, IPV6, Multi-PDP, FTP, FTPS, HTTP, HTTPS, DNS
SMSSupports MT, MO, CB, Text, PDU
Firmware UpgradeSupports USB/FOTA firmware upgrades
Hardware
SIM Card1.8V / 3.0V
Antenna InterfaceIPEX Gen4 interface (LTE main antenna + LTE diversity antenna + GNSS antenna)
Power Supply3V ~ 4.2V
Form FactorM.2 B KEY
Dimensions42.0 × 31.4 × 3.8 mm
4. Pinout Diagram​
SIM7600G-H
5. Usage​
Important Notes
  1. Do not hot-plug devices: Always power off before inserting/removing SIM cards, antennas, or the module to prevent damage or recognition issues. After powering on, if registration is successful, the NET indicator will blink.
  2. Ensure the SIM card is valid: It is recommended to first test with a standard mobile SIM card. Avoid IoT cards with strict limitations. Try SIM cards from different carriers to rule out card failure, insufficient balance, or compatibility issues.
5.1 Status Indicators​
NETStatus
OffPowered off or starting up
OnSearching for network
BlinkingConnected, working normally
On/BlinkShutting down
Tip
The status indicator reflects the module’s internal state. To communicate with the development board, additional configuration is required. After configuration, the board can access the network via the module.
5.2 Common AT Commands​
CommandDescriptionReturn Value
ATAT test commandOK
ATEATE1: Enable echo / ATE0: Disable echoOK
AT+CGMIQuery module manufacturerOK
AT+CGMMQuery module modelOK
AT+CGSNQuery product serial numberOK
AT+CSUBQuery module version and chipsetOK
AT+CGMRQuery firmware versionOK
AT+IPREXSet module UART baud rate+IPREX: OK
AT+CRESETReset moduleOK
AT+CSQQuery signal quality+CSQ: 17,99 OK
AT+CPIN?Query SIM card status; returns READY if recognized+CPIN: READY
AT+COPS?Query current operator; returns carrier info if connected+COPS: OK
AT+CREG?Query network registration status+CREG: OK
AT+CPSI?Query UE system information
AT+CNMPNetwork mode selection: 2=Auto, 13=GSM only, 38=LTE only, 48=Any but LTE...OK
5.3 Usage with Development Boards​
Product NameTutorial
Luckfox Lyra Pi🔗 Luckfox Lyra Pi 4G Dial-up Internet
Luckfox Pico Pi🔗 Luckfox Pico Pi 4G Dial-up Internet
6. Dimensions​
SIM7600G-H
