4. I2C
4.1 Enabling I2C Interface
Core3566 has two I2C channels: I2C-5 (pins 3 and 5) and I2C-3 (pins 27 and 28). I2C-3 is enabled by default, and to enable I2C-5, follow the steps below (refer to the PWM section):
View I2C devices:
inaro@linaro-alip:~$ ls /dev/i2c*/dev/i2c-0 /dev/i2c-1 /dev/i2c-3 -
After configuring with the luckfox-config tool, restart the device and enter the following command in the terminal to check:
ls /dev/i2c* -
The result will show that /dev/i2c-5 has been successfully enabled:
linaro@linaro-alip:~$ ls /dev/i2c*/dev/i2c-0 /dev/i2c-1 /dev/i2c-3 /dev/i2c-5
4.2 Hardware Connection
This example uses the Waveshare 1.5inch OLED Module. For detailed parameters and usage of the module, refer to the Waveshare official Wiki.
Note: The module is initially set to use 4-wire SPI communication, with BS connected to 0. If I2C communication is used, BS needs to be connected to 1 (1 and 0 do not represent the logic level, but rather the resistor soldering method).
Pin connection between Core3566 and 1.5inch OLED Module:
1.5inch OLED Module Core3566 Board Physical Pin Number Function VCC 5V Power Input GND GND Ground DIN I2C5_SDA I2C Data Input CLK I2C5_SCL I2C Clock Signal DC 5V Set device address to 0X3D by pulling DC high -
Wiring Diagram
4.3 i2c-tools
Query I2C device addresses:
i2cdetect -y -r -a 5linaro@linaro-alip:~$ sudo i2cdetect -y -r -a 50 1 2 3 4 5 6 7 8 9 a b c d e f00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --30: -- -- -- -- -- -- -- -- -- -- -- -- -- 3d -- --40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --- Parameters: -y ignores interactive issues and executes directly, -r is the SMBus read byte command, -a is for all addresses, and 5 is for i2c-5.
Scan register data:
sudo i2cdump -y 5 0x3d
4.4 Controlling with Python Program
Download the example program and run it in the terminal:
cd ~/OLED_1in5/sudo python3 OLED_1in5_i2c.py
