16-2K-Touch-Monitor
1. Introduction
The 16inch portable monitor features a 2560 × 1600 high-resolution IPS panel with 100% sRGB color gamut, delivering sharp images and rich, accurate colors. It supports a 178° ultra-wide viewing angle and a refresh rate of up to 165Hz, ensuring smooth and fluid visuals.
The display is equipped with 10-point capacitive touch support, enabling responsive and precise multi-touch interaction. A standard 75mm M4 VESA mounting interface is built into the enclosure, allowing flexible installation and efficient space utilization. Compatible with various standard HDMI devices, the monitor is suitable for a wide range of application scenarios.
2. Product Specifications
| Item | Description | Unit |
| Model | 16-2K-Touch-Monitor | / |
| Size | 16 | Inch |
| Viewing Angle | 178 | Deg |
| Resolution | 2560 × 1600 | Pixels |
| Dimensions | 354.60 (H) × 230.40 (V) | mm |
| Display Area | 344.68 (H) × 215.42 (V) | mm |
| Color Gamut | 100% | sRGB |
| Max Brightness | 300 | cd/m² |
| Contrast | 1200:1 | / |
| Backlight Adj. | OSD Menu | / |
| Refresh Rate | 165 | Hz |
| Display Ports | mini HDMI/Type-C | / |
| Power input | 5 | V |
| Power Consumption | 10.4 | Watt |
3.Interface
4. Menu Button Description
4.1 Button Functions
- Scroll up: Adjust volume
- Scroll down: Adjust brightness
- Press down: Open OSD main menu / Confirm selection
- Scroll within menu: Navigate menu items or adjust values
Power Button
- Short press (outside menu): Open input source selection panel (Auto / Type-C / HDMI)
- Short press (inside menu): Exit menu interface
- Long press: Turn backlight on/off
🔴 Note: Normally, the screen will automatically turn on when a valid signal is detected after power on, no manual button press required.
4.2 OSD Main Menu Overview
- Pressing down the rotary knob enters the OSD main menu, where you can adjust the following:
- Picture: Brightness, Contrast, Shadow Balance, Game Mode
- Advanced: Ultra HDR Mode, Eye Protection Mode, 3D Sound, Crosshair
- Settings: Signal Selection, Language, Aspect Ratio, Volume
- Color Temperature: 6500K / 9300K / Custom
- OSD Settings: Position, Transparency, Menu Timeout
- Color Effects: Saturation, Hue, Sharpness Enhancement
- Information Display: Current Input Source, Resolution, Horizontal Frequency, Pixel Clock
- Reset: Restore factory defaults
5. Using with Raspberry Pi
5.1 Software Configuration
- Connect the TF card to your computer.
- Download and install the Raspberry Pi Imager from the official Raspberry Pi website.
- Open the imager, select the TF card to write the image to (ensure other USB devices are removed to avoid accidental data loss).
- Preconfigure the system by pressing CTRL+SHIFT+X (or clicking the gear icon in the bottom right corner). Save the settings.
- Click the "Write" button to flash the image onto the TF card.
- After flashing, open the
/boot/firmware/directory on the TF card, edit theconfig.txtfile, and add the following lines at the end:
hdmi_force_hotplug=1
hdmi_mode=87
hdmi_timings=2560 0 48 32 80 1600 0 3 6 37 0 0 0 144 0 508000000 3
hdmi_drive=2
config_hdmi_boost=10
- Insert the TF card into the Raspberry Pi.
5.2 Hardware Connection
- Connect the 20W PD power adapter to the power port of the LCD.
- Use a Type-C cable to connect the Raspberry Pi to the display’s one-cable (Type-C) interface.
- Connect the HDMI interface of the LCD to the HDMI interface of the Raspberry Pi, power on the Raspberry Pi. After waiting for a few seconds, the LCD will display and touch normally.
6. Using with PC
Supports PC version of Windows 11 / 10 / 8.1 / 8 / 7 system.
- Connect the Type-C cable to the PC and the touch port of the LCD.
- Connect the HDMI interface of the LCD to the HDMI interface of the PC. After waiting for a few seconds, the LCD will display and touch normally.
7. Using with One-Cable Connection Devices
- Connect the full-function Type-C interface of the LCD to the Type-C interface of the device. Wait for a while and it will display normally.
8. Dimensions
Q: How to enable 165Hz refresh rate in Windows?
💡: Generally, Windows will automatically detect and set the optimal resolution and refresh rate for your monitor. If it does not automatically set to 120Hz, please follow the steps below to adjust manually:
Adjust Windows Display Settings:
- Go to Windows Display Settings, then select Advanced display settings.
- In the Choose display dropdown menu, select the Wired Display, then click Display adapter properties.
- In the pop-up window, switch to the Monitor tab, select 165Hz from the Screen refresh rate dropdown menu. Click Apply and confirm the change.
Note: If the 165Hz option does not appear in advanced display settings, please check the following:
Ensure your device supports 165Hz refresh rate:
- Your graphics card must support 165Hz output; verify your device configuration meets the requirements. If the issue persists, try updating the graphics driver.
Confirm the cables and interface version support 165Hz:
- Use cables that support high refresh rates (e.g., HDMI 1.4 or above, or Type-C with DisplayPort support)
Provide stable power supply to the monitor:
- To ensure proper operation at 165Hz, use the provided 20W external power adapter.
