Image Flashing
1. Equipment Preparation
- Luckfox Lyra Development Board
- USB Type-A to Type-C Data Cable
2. Image Download
Lyra Plus provides an image tailored for DSI displays. Users can download the image file based on their specific needs. The naming convention for images is as follows:Luckfox-(Board Model)-(Board System)-(Storage Medium)-(Update Date)
Board Model: Lyra, Lyra B, and Lyra Plus
Board System: Ubuntu, Buildroot
Storage Medium: SPI NAND FLASH and TF Card
Version Description Download Ubuntu Image for TF Card Google Drive Download Link Builldroot Image for Flash and TF Card Google Drive Download Link
3. Installing Drivers
Download the RK Driver Assistant DriverAssitant-RK Driver Assistant and the flashing tool RKDevTool.
Open RK Driver Assistant to install the USB drivers. This process does not require the board to be connected. Restart your computer after installation is complete.
3.1 Entering Upgrade Mode
Loader Mode and MaskRom Mode are two common upgrade modes for devices, used to load firmware or boot programs.
Loader Mode loads via software-level boot programs, typically for firmware upgrades.
MaskRom Mode is a hardware-level boot mode, used for factory flashing or device recovery.
3.1.1 Loader Mode
The development board comes with a pre-installed testing image to verify functionality. Upon receiving the board, users must reflash a new image. Before reflashing the system, switch the board to either Loader Mode or MaskRom Mode. Loader Mode is recommended for most cases.
Open the RKDevTool tool.
Hold the BOOT button while connecting the board to your computer. Release the BOOT button after connecting. When the tool displays the message
Found One LOADER Device, you can proceed with flashing.If already connected, you can hold RESET, then press and hold BOOT. Release RESET and wait for the tool to detect the Loader Mode device before releasing BOOT.
Note: If the device is not detected as a Loader Device, check the device manager to ensure the board is recognized correctly. The device manager should display:
- Flashing Mode:
- Non-Flashing Mode (with normal kernel boot, LED blinking):
- Flashing Mode:
3.1.2 MaskRom Mode (Use with Caution)
If the device cannot enter Loader Mode, try forcing MaskRom Mode:
- Connect the board and open RKDevTool.
- Disconnect power, short the FSPI_CLK and GND pins on the Flash chip, then reconnect USB. Once the flashing software detects the device, remove the short connection.
- Power on the board. The tool should display
Found One MASKROM Device. After flashing, remove the jumper cap.
4. Flashing Images (SPI NAND FLASH)
4.1 Windows
Flashing an Image
Open RKDevTool. Ensure the device is in
MASKROM/LOADER mode. Click Firmware, select the image path, and load theupdate.imgfile.
Wait for the image to load, then click Upgrade.
Once completed, the tool will display Download Successful.
Flashing Kernel Files
- Update the firmware by importing the configuration file into RKDevTool.
- Select all files and open
parameter.txt.
- Once loaded successfully.
- Select
MiniLoaderAll.binandboot, then click Run to update the firmware.
4.2 Linux(X86_64 Platform)
Upgrade_Tool is a command-line tool for flashing raw firmware, RK firmware, and partition images to eMMC under Linux. This closed-source tool from Rockchip supports flashing only to SPI NAND FLASH. For TF card flashing, use SDDiskTool on Windows. The rkflash.sh script and Upgrade_Tool are included in the SDK, which is recommended to run on Ubuntu 22.04 (testing is done on this version).
- Hold the BOOT button while connecting the board to the host. Use
lsusbto check for device recognition. Replace the Type-C cable if the device is not detected.- "ADB" mode:
- "LOADER" mode:
- "MASKROM" mode:
- "ADB" mode:
Flashing can only be performed when the Lyra main unit is in "LOADER" or "MASKROM" mode.
Download and extract the SDK. For specific operations, refer to the《Setting Up SDK Development Environment》section.
$ ls -l
total 3124652
drwxrwxr-x 4 ubuntu ubuntu 4096 12月 13 17:16 app
drwxrwxr-x 19 ubuntu ubuntu 4096 12月 13 18:35 buildroot
lrwxrwxrwx 1 ubuntu ubuntu 39 12月 13 17:16 build.sh -> device/rockchip/common/scripts/build.sh
lrwxrwxrwx 1 ubuntu ubuntu 22 12月 13 17:19 common -> device/rockchip/common
drwxrwxr-x 3 ubuntu ubuntu 4096 12月 13 17:16 device
drwxrwxr-x 8 ubuntu ubuntu 4096 12月 13 17:16 docs
drwxrwxr-x 16 ubuntu ubuntu 4096 12月 13 17:16 external
drwxrwxr-x 11 ubuntu ubuntu 4096 12月 13 17:16 hal
lrwxrwxrwx 1 ubuntu ubuntu 10 12月 13 17:17 kernel -> kernel-6.1
drwxrwxr-x 27 ubuntu ubuntu 4096 12月 13 19:39 kernel-6.1
lrwxrwxrwx 1 ubuntu ubuntu 31 12月 13 17:16 Makefile -> device/rockchip/common/Makefile
drwxrwxr-x 7 ubuntu ubuntu 4096 12月 13 19:40 output
drwxrwxr-x 3 ubuntu ubuntu 4096 12月 13 17:17 prebuilts
lrwxrwxrwx 1 ubuntu ubuntu 32 12月 13 17:19 README.md -> device/rockchip/common/README.md
-rw-r--r-- 1 ubuntu ubuntu 3199580732 12月 13 17:09 repo_1213.tar.gz
drwxrwxr-x 10 ubuntu ubuntu 4096 12月 13 18:35 rkbin
lrwxrwxrwx 1 ubuntu ubuntu 41 12月 13 17:16 rkflash.sh -> device/rockchip/common/scripts/rkflash.sh
lrwxrwxrwx 1 ubuntu ubuntu 15 12月 13 19:40 rockdev -> output/firmware
drwxrwxr-x 15 ubuntu ubuntu 4096 12月 13 17:17 rtos
drwxrwxr-x 6 ubuntu ubuntu 4096 12月 13 17:17 tools
drwxrwxr-x 28 ubuntu ubuntu 4096 12月 13 18:35 u-boot
drwxrwxr-x 8 ubuntu ubuntu 4096 12月 13 17:17 yoctoExecute the script with administrator privileges.
Using /home/ubuntu/Luckfox/rk3506/luckfox-lyra-sdk/tools/linux/Linux_Upgrade_Tool/Linux_Upgrade_Tool/config.ini
Support Type:350F FW Ver:8.1.00 FW Time:2024-12-13 19:40:06
Loader ver:1.01 Loader Time:2024-12-13 18:35:14
Upgrade firmware ok.Expected results:
4.3 Mac OS
Download and extract upgrade_tool:
sudo ditto -xk upgrade_tool_v2.3_mac.zip .Run the program to flash the firmware (please modify the path according to the actual location of the image):
cd upgrade_tool_v2.3_mac
sudo ./upgradetool uf Luckfox-RK3576-Debian12-Xfce-HDMI-202409.imghe result will be as follows:
4.4 Image Erasure
- To erase data in the eMMC, select the update.img firmware and click Erase Flash:
5. TF Card Image Flashing
Download the TF card erasure tool SD Card Formatter, extract and install it with one click.
Select the TF card drive letter and click Format (be sure to remove other TF cards to avoid data loss)
Download the TF card flashing tool SDDiskTool, extract and use without installation.
