Install an operating system
1. Overview
The Luckfox Pico Pi series development boards come pre - installed with eMMC. At the time of leaving the factory, they are loaded with a test system. The factory image is mainly used to check whether the interface functions of the development board are in normal condition and is updated relatively infrequently. To ensure the proper operation of the development board, it is advisable that users use tools such as a USB Type - A to Type - C data cable to burn the system image provided in the network disk on their own after receiving the board.
Before flashing the firmware image, make sure to check the development board’s status: the DIP switch should be set to the “ON” position.
2. Driver Installation
- Download the RK DriverAssitant(click here to download).
- Open the RK Driver Assistant to install the USB driver. There is no need to connect during this process. After the installation is complete, restart the computer.
The Luckfox Pico Pi series offers images for Buildroot and Ubuntu22.04. Users can download the image files according to their requirements.
Officially Supported Image Download
The Luckfox Pico Pi series provides images based on Buildroot. Users can download the image files according to their needs.
| Version | Description | Download |
| Buildroot | Standard models (A/B): Burn the Luckfox_Pico_Pi_EMMC_250313 firmware Wireless models (A/B W): Burn the Luckfox_Pico_Pi_W_EMMC_250313 firmware | Google Driver |
Community-Supported Image Download
| Ubuntu22.04 | Standard models (A/B): Burn the Ubuntu_Luckfox_Pico_Pi_EMMC_250313 firmware Wireless models (A/B W): Burn the Ubuntu_Luckfox_Pico_Pi_W_EMMC_250313 firmware | Google Driver |
4. Flashing the Image (Windows Environment)
The SocToolKit software supports two flashing modes for eMMC or Flash:
One-click full image flashing: This mode uses a pre-packaged full system image containing all required partitions. It is suitable for rapid deployment and enables quick system setup.
Selective partition flashing: This allows updating specific system modules, offering a flexible flashing solution for users with advanced customization needs.
- These two flashing modes are independent. Choose the one that fits your needs — only one is required during the actual operation.
- If the development board is successfully connected via ADB, you can directly execute the command
reboot loaderto quickly enter flashing mode without manually pressing any buttons.
- Download and extract the SocToolKit flashing tool(Click here to download).
- Open the software(right-click and run as administrator),then select RV1106.
- Device connection and partition image flashing:
① While holding down the BOOT button, connect the board to your PC. Release the BOOT button once the Rockchip flashing tool displays aMaskRomdevice (device number may vary).
② Click Search Path to select the firmware directory, check all the partitions you want to flash, then click the Download button to start flashing.
- Device connection and one-click full image flashing:
② Click Firmware to select the firmware directory, then click the Upgrade button to start flashing.
5. Image Flashing (Linux Environment)
- Currently supported only on Ubuntu 22.04 x86_64. Other platforms or architectures are not compatible at this time.
- upgrade_tool is a closed-source command-line flashing utility provided by Rockchip, supporting only SPI NAND Flash and eMMC as target storage media.
5.1 Entering Flash Mode on the Development Board
Press and hold the BOOT button while connecting the board to the host PC to enter flash mode.
After running the lsusb command, you can compare the device recognition results between flash mode and normal operating mode, as shown below:
- Board in flash mode:
- Board successfully booted into the system:
- Faulty USB cable: If replugging the cable causes no response and no system or VMware popup appears, the cable is likely damaged or has a poor connection. Try replacing the USB cable and reconnecting the board.
- Device not assigned in VMware popup: When plugging in the board, VMware will prompt you to choose whether to connect the device to the “Host” or “Virtual Machine.”
If no selection is made before the popup disappears and VMware’s auto-connect policy is not properly configured, the device remains unassigned, meaning it is neither controlled by the host nor mounted to the VM.
In this case, replug the device to reassign control.
5.2 Flashing Standalone Image (Without SDK)
Download, extract, and install upgrade_tool :
sudo chmod +x /usr/local/bin/upgrade_toolVerify installation success:
Upgrade Tool v2.17Run the tool to flash the firmware:
Download Boot Start
Download Boot Success
Wait For Maskrom Start
Wait For Maskrom Success
Upgrade firmware ok.Result preview:
5.3 Flashing the Image via SDK Script
- Ensure the board is in flash mode before proceeding.
- Run the flashing script with administrator privileges:
Download Boot Start
Upgrade firmware ok - Result preview:
6. Image Flashing (macOS Environment)
The upgrade_tool is available not only for Linux but also supports the macOS platform.
Download and extract the appropriate version of the Upgrade Tool flashing utility according to your Mac’s processor architecture.
OS Version Upgrade Tool Version Download MacOS 12.7 upgrade_tool_v2.25_for_mac.zip Download MacOS 26.1 upgrade_tool_v2.44_for_mac.zip Download Press and hold the BOOT button while connecting the device to the host computer to put the board into flashing mode.
[Note] The following command is only an example. Please modify the image file name and path according to the actual image file you are using.
cd upgrade_tool_v2.44_mac
sudo ./upgrade_tool uf Luckfox-xxx-xxx.imgThe result is shown below.
