Luckfox-Pico-86-Panel
Product Introduction
The Luckfox-Pico-86-Panel is based on the Rockchip RV1106 G2/G3 chip. RV1106 is a highly integrated IPC (Intelligent Video Processor) vision processing SoC specifically designed for artificial intelligence applications. It is built on a single-core ARM Cortex-A7 32-bit core, integrated with NEON and FPU, and features a built-in NPU supporting mixed-precision operations of INT4/INT8/INT16, with computing capabilities of up to 0.5TOPs/1TOPs. The embedded 16-bit DRAM DDR3L maintains demanding memory bandwidth, while the integrated POR (Power-on Reset), audio codec, and MAC PHY further enhance its functionality.
The development board supports multiple interfaces, including GPIO, UART, SPI, I2C, USB, etc., facilitating rapid development and debugging for developers. Notably, all development boards in the Luckfox Pico series support the Buildroot system, allowing developers to select appropriate systems according to project requirements and flexibly meet specific application needs.
Product Specifications
Luckfox-Pico-86-Panel-0408Luckfox-Pico-86-Panel-1408Luckfox-Pico-86-Panel-0208Luckfox-Pico-86-Panel-1208
ChipRV1106G3RV1106G2
ProcessorCortex A7 1.2GHz
NPU1 TOPS, supports INT4/INT8/INT160.5 TOPS, supports INT4/INT8/INT16
VEPUSupports H264/H265 video encoding
ISPMax input 5M @30fps
Memory256MB DDR3L128MB DDR3L
Wi-Fi + Bluetooth/2.4GHz WiFi6 Bluetooth 5.2/BLE/2.4GHz WiFi6 Bluetooth 5.2/BLE
Default Storage MediumeMMC(8GB)
Ethernet Port10/100M Ethernet controller and embedded PHY
Audio Interface1 x SMT microphone
1 x Microphone expansion interface (MX1.25mm-2P)
USB1 x USB Device
RTC1 x RTC coin cell battery holder
Relay Interface2 x Common terminal/Normally open terminal
RS4851 x RS485
Power InterfaceDC 6V~30V wide voltage range input
