LVGL User Guide
In this article, we will provide a detailed explanation of the basic concepts of the Framebuffer (FB) device and the LittlevGL (LVGL) graphics user interface library. By using the Luckfox Pico Pro/Max development board and the Pico-LCD-1.3 display, we will demonstrate how to configure the FB device, create applications using the LVGL library, and finally display the interface on the LCD.
Quick Start
Note: Only Luckfox Pico / Plus / Pro / Max supports FBTFT configuration, and currently only supports ST7789v/ ST7789vm display chips. The FBTFT configuration requires a reboot to take effect.
Navigate to Compatible Devices -> FBTFT screen, select
enable
to enter the FBTFT mode configuration screen.If SPI0M0 is enabled, FBTFT cannot be configured.
If the pins to be configured are multiplexed for other functions and marked, selecting
enable
will display a prompt message. You need to disable the conflicting configuration to successfully enable FBTFT.Download the LVGL sample program.
version Description Download LVGL.zip LVGL Test Program LVGL.zip Directory of the compressed package:
LVGL/
├── image ----------------------------------- Image files
├── lvgl_demo ------------------------------- Project directory
├── demo ------------------------------------- Executable files
└── rv1106g-luckfox-pico-pro-max.dts -------- Device tree fileUpload the sample program to the development board and run it.
chmod +x demo
./demoExpected results:
Hardware connections
Display effects
1. Framebuffer (FB) Devices
The two commonly used graphics display device driver frameworks in the Linux kernel are DRM (Direct Rendering Manager) and FBDEV (Framebuffer Device). Under the Framebuffer driver framework, users can directly operate the display device's video memory through the /dev/fbX
interface, performing standard file operations (such as read
, write
, ioctl
). User-space programs can control the framebuffer device through these device nodes and ioctl
calls. Framebuffer provides basic 2D graphics operations, such as drawing points, lines, and rectangles, and supports various pixel formats and resolutions.
1.1 Kernel Configuration
For detailed usage methods regarding adding to the kernel, refer to the "SDK Environment Deployment" section.
Enter the kernel directory.
cd /SDK Directory/
./build.sh kernelconfigEnable FB-related drivers in the kernel sequentially.
CONFIG_VT_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FONTS=y
1.2 Device Tree Files
To drive the LCD, in addition to enabling FB-related drivers in the kernel, it is essential to ensure that all pins communicating with the LCD function correctly. Before this, we need to determine the connection pins between Pico-LCD-1.3 and Luckfox Pico Pro/Max. The device tree is used to describe hardware resources, so corresponding modifications to the device tree are required.
1.2.1 Related Pins
It is important to note that the internal circuit of Pico-LCD-1.3 performs forced level conversion, converting the input voltage (VSYS) to a stable 3.3V, so VSYS can be used for power supply. More details on the pins can be referenced in the Pico-LCD-1.3 Wiki tutorial.
LCD | Luckfox Pico Pro/Max | Function |
VCC | VSYS | Power input |
GND | GND | Ground |
DIN | SPI0_MOSI_M0 | SPI communication MOSI pin, data input from device |
CLK | SPI0_CLK_M0 | SPI communication SCK pin, clock input from device |
CS | SPI0_CS0_M0 | SPI chip select pin (active low) |
DC | GPIO2_B1_d | Data/Command control pin (high for data, low for command) |
RST | GPIO1_C3_d | External reset pin (active low) |
BL | GPIO2_B0_d | Backlight control |
A | GPIO1_D1_d | User key A |
B | GPIO2_A5_d | User key B |
X | GPIO2_A1_d | User key X |
Y | GPIO2_A3_d | User key Y |
UP | GPIO1_C7_d | Joystick up |
DOWM | GPIO2_A0_d | Joystick down |
LEFT | GPIO2_A4_d | Joystick left |
RIGHT | GPIO2_A2_d | Joystick right |
CTRL | GPIO1_C6_d | Joystick press |
1.2.2 Writing the Device Tree
In the default device tree, GPIO1_C7_d's default function is PWM. In the program, we want to read the pin level to determine the key state, so we need to configure this pin as a general I/O. Open
<SDK Directory>/sysdrv/source/kernel/arch/arm/boot/dts/rv1106g-luckfox-pico-pro-max.dts
gpio1pc7:gpio1pc7 {
pinctrl-0 = <&gpio1_pc7>;
regulator-name = "gpio1_pc7";
regulator-always-on;
gpio1-pc7 {
gpio1_pc7:gpio1-pc7 {
};- For the complete device tree, please download the device tree file from the cloud drive; this is just a partial display.
The SPI configuration requires disabling
spidev@0
; otherwise,fb
cannot be initialized.&spi0 {
status = "okay";
pinctrl-0 = <&spi0m0_clk &spi0m0_mosi &spi0m0_cs0>;
spidev@0 {
status = "disabled";
fbtft@0{
status = "okay";
compatible = "sitronix,st7789v";
reg = <0>;
spi-max-frequency = <20000000>;
fps = <30>;
buswidth = <8>;
debug = <0x7>;
led-gpios = <&gpio2 RK_PB0 GPIO_ACTIVE_LOW>;//BL
dc = <&gpio2 RK_PB1 GPIO_ACTIVE_HIGH>; //DC
reset = <&gpio1 RK_PC3 GPIO_ACTIVE_LOW>; //RES
};After modifying the device tree, compile the image and test with color noise and clearing the screen.
cat /dev/urandom > /dev/fb0 # Color noise
cat /dev/zero > /dev/fb0 # Clear screen
2. Porting LVGL(PC)
2.1 Required Resources
Resource Name | Repository Address | Description |
lvgl | https://github.com/lvgl/lvgl.git | Source code of LVGL graphics controls and a few examples |
lv_drivers | https://github.com/lvgl/lv_drivers.git | Driver interface source code for driving LVGL graphics interface |
lv_demos | https://github.com/lvgl/lv_demos.git | LVGL examples |
lv_port_linux_frame_buffer | https://github.com/lvgl/lv_port_linux_frame_buffer.git | Interface for adapting to Linux systems with Framebuffer |
2.2 Fetch Resources
Create a folder in the root directory to store the official source code:
luckfox@luckfox:~$ mkdir lvgl
luckfox@luckfox:~$ cd lvgl
Fetch the resources:
git clone -b v8.1.0 https://github.com/lvgl/lvgl.git
git clone -b v8.1.0 https://github.com/lvgl/lv_drivers.git
git clone -b v8.1.0 https://github.com/lvgl/lv_demos.git
git clone --branch release/v8.2 --single-branch https://github.com/lvgl/lv_port_linux_frame_buffer.git
After successful fetching, create a project directory in the root directory and create a project:
luckfox@luckfox:~$ mkdir lvgl_project
luckfox@luckfox:~$ cd lvgl_project/
luckfox@luckfox:~/lvgl_project$ mkdir project_01
luckfox@luckfox:~/lvgl_project$ cd project_01/
2.3 Copy Files
- Copy the lvgl and lv_drivers directories from the root directory
- Copy main.c and Makefile from lv_port_linux_frame_buffer
- Copy lv_conf_template.h from lvgl and rename it to lv_conf.h
- Copy lv_drv_conf_template.h from lv_drivers and rename it to lv_drv_conf.h
cp -r ~/lvgl/lvgl ./
cp -r ~/lvgl/lv_drivers ./
cp ~/lvgl/lvgl/lv_conf_template.h ./lv_conf.h
cp ~/lvgl/lv_drivers/lv_drv_conf_template.h ./lv_drv_conf.h
cp ~/lvgl/lv_port_linux_frame_buffer/main.c ./
cp ~/lvgl/lv_port_linux_frame_buffer/Makefile ./
Check the project_01 project directory:
luckfox@luckfox:~/lvgl_project/project_01$ ls -l
total 64
-rw-rw-r-- 1 luckfox luckfox 29023 12月 27 19:14 lv_conf.h
drwxrwxr-x 12 luckfox luckfox 4096 12月 27 19:14 lv_drivers
-rw-rw-r-- 1 luckfox luckfox 15184 12月 27 19:14 lv_drv_conf.h
drwxrwxr-x 12 luckfox luckfox 4096 12月 27 19:14 lvgl
-rw-rw-r-- 1 luckfox luckfox 2350 12月 27 19:14 main.c
-rw-rw-r-- 1 luckfox luckfox 2321 12月 27 19:14 Makefile
2.4 Modify Files
lv_conf.h
Enable
Change
#if 0
to#if 1
at the beginning/* clang-format off */
#if 1 /*Set it to "1" to enable content*/Allocate VRAM
Enable
LV_MEM_CUSTOM
and choose to allocate VRAM manually/*1: use custom malloc/free, 0: use the built-in `lv_mem_alloc()` and `lv_mem_free()`*/
#define LV_MEM_CUSTOM 1Refresh time
Change the original 30ms to 10ms
/*Default display refresh period. LVG will redraw changed areas with this period time*/
#define LV_DISP_DEF_REFR_PERIOD 10 /*[ms]*/
/*Input device read period in milliseconds*/
#define LV_INDEV_DEF_READ_PERIOD 10 /*[ms]*/TICK Configuration
Enable
LV_TICK_CUSTOM
and choose to customize the Tick timer configuration function in the applicationOriginal content:
#define LV_TICK_CUSTOM 0
#if LV_TICK_CUSTOM
#define LV_TICK_CUSTOM_INCLUDE "Arduino.h" /*Header for the system time function*/
#define LV_TICK_CUSTOM_SYS_TIME_EXPR (millis()) /*Expression evaluating to current system time in ms*/
#endif /*LV_TICK_CUSTOM*/Change to:
#define LV_TICK_CUSTOM 1
#if LV_TICK_CUSTOM
#define LV_TICK_CUSTOM_INCLUDE <stdint.h> /*Header for the system time function*/
#define LV_TICK_CUSTOM_SYS_TIME_EXPR (custom_tick_get()) /*Expression evaluating to current system time in ms*/
lv_drv_conf.h
Enable
Change
#if 0
to#if 1
#if 1 /*Set it to "1" to enable the content*/Support devices
Enable
USE_FBDEV
to support Framebuffer devices/*-----------------------------------------
* Linux frame buffer device (/dev/fbx)
#ifndef USE_FBDEV
# define USE_FBDEV 1
#endif
#if USE_FBDEV
# define FBDEV_PATH "/dev/fb0"
#endif
Makefile
Replace the original content of the Makefile, and modify <SDK Directory\>
in the Makefile to your SDK path, e.g., /home/luckfox/luckfox-pico/
# Makefile
CC = <SDK Directory>/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf-gcc
LVGL_DIR_NAME ?= lvgl
LVGL_DIR ?= .
WARNINGS := -Wall -Wshadow -Wundef -Wmissing-prototypes -Wno-discarded-qualifiers -Wall -Wextra -Wno-unused-function -Wno-error=strict-prototypes -Wpointer-arith \
-fno-strict-aliasing -Wno-error=cpp -Wuninitialized -Wmaybe-uninitialized -Wno-unused-parameter -Wno-missing-field-initializers -Wtype-limits -Wsizeof-pointer-memaccess \
-Wno-format-nonliteral -Wno-cast-qual -Wunreachable-code -Wno-switch-default -Wreturn-type -Wmultichar -Wformat-security -Wno-ignored-qualifiers -Wno-error=pedantic \
-Wno-sign-compare -Wno-error=missing-prototypes -Wdouble-promotion -Wclobbered -Wdeprecated -Wempty-body -Wtype-limits -Wshift-negative-value -Wstack-usage=2048 \
-Wno-unused-value -Wno-unused-parameter -Wno-missing-field-initializers -Wuninitialized -Wmaybe-uninitialized -Wall -Wextra -Wno-unused-parameter \
-Wno-missing-field-initializers -Wtype-limits -Wsizeof-pointer-memaccess -Wno-format-nonliteral -Wpointer-arith -Wno-cast-qual -Wmissing-prototypes \
-Wunreachable-code -Wno-switch-default -Wreturn-type -Wmultichar -Wno-discarded-qualifiers -Wformat-security -Wno-ignored-qualifiers -Wno-sign-compare -std=c99
CFLAGS ?= -O3 -g0 -I$(LVGL_DIR)/ $(WARNINGS)
LDFLAGS ?= -lm
BIN = demo
BUILD_DIR = ./build
BUILD_OBJ_DIR = $(BUILD_DIR)/obj
BUILD_BIN_DIR = $(BUILD_DIR)/bin
prefix ?= /usr
bindir ?= $(prefix)/bin
#Collect the files to compile
MAINSRC = $(wildcard ./*.c)
include $(LVGL_DIR)/lvgl/lvgl.mk
include $(LVGL_DIR)/lv_drivers/lv_drivers.mk
# CSRCS +=$(LVGL_DIR)/mouse_cursor_icon.c
OBJEXT ?= .o
AOBJS = $(ASRCS:.S=$(OBJEXT))
COBJS = $(CSRCS:.c=$(OBJEXT))
MAINOBJ = $(MAINSRC:.c=$(OBJEXT))
SRCS = $(ASRCS) $(CSRCS) $(MAINSRC)
OBJS = $(AOBJS) $(COBJS) $(MAINOBJ)
TARGET = $(addprefix $(BUILD_OBJ_DIR)/, $(patsubst ./%, %, $(OBJS)))
## MAINOBJ -> OBJFILES
all: default
$(BUILD_OBJ_DIR)/%.o: %.c
@mkdir -p $(dir $@)
@$(CC) $(CFLAGS) -c $< -o $@
@echo "CC $<"
default: $(TARGET)
@mkdir -p $(dir $(BUILD_BIN_DIR)/)
$(CC) -o $(BUILD_BIN_DIR)/$(BIN) $(TARGET) $(LDFLAGS)
clean:
rm -rf $(BUILD_DIR)
install:
install -d $(DESTDIR)$(bindir)
install $(BUILD_BIN_DIR)/$(BIN) $(DESTDIR)$(bindir)
uninstall:
$(RM) -r $(addprefix $(DESTDIR)$(bindir)/,$(BIN))
main.c
Comment out header files
// #include "lvgl/demos/lv_demos.h"
// #include "lv_drivers/indev/evdev.h"Modify screen resolution
#define DISP_BUF_SIZE (240 * 240)
disp_drv.hor_res = 240;
disp_drv.ver_res = 240;Comment out the following code
No external input device, comment out the following code:
evdev_init();
static lv_indev_drv_t indev_drv_1;
lv_indev_drv_init(&indev_drv_1); /*Basic initialization*/
indev_drv_1.type = LV_INDEV_TYPE_POINTER;
/*This function will be called periodically (by the library) to get the mouse position and state*/
indev_drv_1.read_cb = evdev_read;
lv_indev_t *mouse_indev = lv_indev_drv_register(&indev_drv_1);Mouse style not ported, comment out the following code:
/*Set a cursor for the mouse*/
LV_IMG_DECLARE(mouse_cursor_icon)
lv_obj_t * cursor_obj = lv_img_create(lv_scr_act()); /*Create an image object for the cursor */
lv_img_set_src(cursor_obj, &mouse_cursor_icon); /*Set the image source*/
lv_indev_set_cursor(mouse_indev, cursor_obj); /*Connect the image object to the driver*/Not using official demo, comment out the following code:
/*Create a Demo*/
lv_demo_widgets();
2.5 Compile and Run
After modifying the above files, enter the make
command in the command line to compile the project. After compiling, an executable file demo
will be generated in the /build/bin
directory. The compiled directory structure is as follows:
project_01/
├── build
│ ├── bin
│ │ └── demo
│ └── obj
│ ├── lv_drivers
│ ├── lvgl
├── lv_conf.h
├── lv_drivers
├── lv_drv_conf.h
├── lvgl
├── main.c
└── Makefile
You only need to copy demo
to the development board to run the program. You can later modify the main.c
file and add files according to your requirements to achieve the desired display effect.
2.6 Official Demo
If you need to use the examples provided by the official, follow these steps:
Copy files
Copy the lv_demos directory from the root directory
Copy lv_demo_conf_template.h from lv_demos and rename it to lv_demo_conf.h
cp -r ~/lvgl/lv_demos ./
cp ~/lvgl/lv_demos/lv_demo_conf_template.h ./lv_demo_conf.h
Modify lv_demo_conf.h
Enable
#if 1 /*Set it to "1" to enable the content*/Enable widget demo
/*Show some widget*/
#define LV_USE_DEMO_WIDGETS 1
Modify lv_conf.h
Enable
LV_FONT_MONTSERRAT_12
andLV_FONT_MONTSERRAT_16
#define LV_FONT_MONTSERRAT_12 1
#define LV_FONT_MONTSERRAT_16 1Makefile
#Add lv_demo.mk:
include $(LVGL_DIR)/lv_demos/lv_demo.mkModify main.c
Add header files
#include "lv_demos/lv_demo.h"
Call interface functions
lv_demo_widgets();
while(1) {
lv_timer_handler();
usleep(5000);
3. Example Program
3.1 Project Directory
After burning the image and creating the project files, you can start modifying the program yourself. Here, we use the Luckfox Pico Pro/Max development board and Pico-LCD-1.3 display screen to implement interface display. The modified project directory is as follows:
lvgl_demo/
├── cat.c -------------------- File obtained after converting the image
├── galaxy.c ----------------- File obtained after converting the image
├── Luckfox.c ---------------- File obtained after converting the image
├── saint.c ------------------ File obtained after converting the image
├── main.c ------------------- Main program file
├── Debug.h ------------------ Debug information header file
├── DEV_Config.c ------------- GPIO control interface file
├── DEV_Config.h ------------- GPIO control interface header file
├── sysfs_gpio.c ------------- sysfs GPIO control implementation file
├── sysfs_gpio.h ------------- sysfs GPIO control header file
3.2 Display Custom Images
Convert online
Convert images
Note that for PNG images, choose the CF_TRUE_COLOR_ALPHA color format, and for JPG images, choose CF_TRUE_COLOR. After conversion, copy the C file to the project directory
Modify main.c
Add declarations
LV_IMG_DECLARE(Luckfox);
Display images
lv_obj_t *scr = lv_disp_get_scr_act(NULL);
lv_obj_t *img = lv_img_create(scr);
lv_show_img(img,Luckfox);
lv_obj_center(img);
3.3 Main Program
main.c
#include "lvgl/lvgl.h"
#include "DEV_Config.h"
#include "lv_drivers/display/fbdev.h"
#include <pthread.h>
#include <time.h>
#include <sys/time.h>
/*Image declare*/
LV_IMG_DECLARE(cat);
LV_IMG_DECLARE(galaxy);
LV_IMG_DECLARE(saint);
void fbdev_flush(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p);
* A meter with multiple arcs
void lv_show_img(lv_obj_t * img,const lv_img_dsc_t img_dat){
lv_obj_clean(img);
lv_img_set_src(img, &img_dat);
lv_obj_center(img);
int main(void)
/*LittlevGL init*/
lv_init();
/*Linux frame buffer device init*/
fbdev_init();
/*A small buffer for LittlevGL to draw the screen's content*/
static lv_color_t buf[DISP_BUF_SIZE];
/*Initialize a descriptor for the buffer*/
static lv_disp_draw_buf_t disp_buf;
lv_disp_draw_buf_init(&disp_buf, buf, NULL, DISP_BUF_SIZE);
/*Initialize and register a display driver*/
static lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.draw_buf = &disp_buf;
disp_drv.flush_cb = fbdev_flush;
lv_disp_drv_register(&disp_drv);
/*Initialize pin*/
DEV_ModuleInit();
/*Show an image*/
lv_obj_center(img);
/*Create a cursor*/
lv_obj_t *cursor = lv_img_create(scr);
lv_img_set_src(cursor, LV_SYMBOL_GPS);
lv_obj_set_pos(cursor, 70, 120);
int x=70,y=120,move=0;
/*Handle LitlevGL tasks (tickless mode)*/
while(1) {
lv_timer_handler();
usleep(5000);
/*Key*/
if(GET_KEYA == 0){
else if(GET_KEYB == 0){
lv_show_img(img,cat);
else if(GET_KEYX == 0){
lv_show_img(img,galaxy);
else if(GET_KEYY == 0){
lv_show_img(img,saint);
/*Joystick*/
if(GET_KEY_UP == 0){
x += 1;
if(x > 226)x = 226;
move =1;
else if(GET_KEY_DOWN == 0){
x -= 1;
if(x < 0)x = 0;
move =1;
else if(GET_KEY_LEFT == 0){
y -= 1;
if(y < 0)y = 0;
move =1;
else if(GET_KEY_RIGHT == 0){
y += 1;
if(y > 224)y = 224;
move =1;
else if(GET_KEY_PRESS == 0){
x = 70;
y = 120;
move =1;
if(move == 1){
lv_obj_set_pos(cursor, x, y);
move = 0;
/*Set in lv_conf.h as `LV_TICK_CUSTOM_SYS_TIME_EXPR`*/
uint32_t custom_tick_get(void)
static uint64_t start_ms = 0;
if(start_ms == 0) {
struct timeval tv_start;
gettimeofday(&tv_start, NULL);
start_ms = (tv_start.tv_sec * 1000000 + tv_start.tv_usec) / 1000;
struct timeval tv_now;
gettimeofday(&tv_now, NULL);
uint64_t now_ms;
now_ms = (tv_now.tv_sec * 1000000 + tv_now.tv_usec) / 1000;
uint32_t time_ms = now_ms - start_ms;
return time_ms;
Code analysis:
Image Declarations
Sequentially declare the images that will be used in the program
/*Image declare*/
Pin Initialization
Call the interface to initialize the control pins of the LCD
/*Initialize pin*/
DEV_ModuleInit();
Display Images
This code segment is used to display an image in the LVGL graphics interface and center the image on the currently active screen.
/*Show an image*/
lv_obj_center(img);
: Get the currently active screen object.lv_obj_t *scr
points to this screen object.lv_img_create(scr)
: Create an image object on the screen object.lv_obj_t *img
points to the created image object.lv_show_img(img, Luckfox)
: Display the image namedLuckfox
on the created image object.lv_obj_center(img)
: Center the image object on the screen.
When the user presses buttons A, B, X, and Y separately, control the LCD to display different images.
/*Key*/
if(GET_KEYA == 0){
Display Cursor
The purpose of this code is to create a cursor object, set the position and image source of the cursor.
/*Create a cursor*/
lv_img_create(scr)
: Creates an image object on the screen.lv_obj_t *cursor
points to the created image object, which will be used as a cursor.lv_img_set_src(cursor, LV_SYMBOL_GPS)
: Sets the image source of the cursor to the GPS symbol.LV_SYMBOL_GPS
is a GPS symbol defined in the LVGL library.lv_obj_set_pos(cursor, 70, 120)
: Sets the position of the cursor to(70, 120)
.int x = 70, y = 120, move = 0;
: Defines three variables representing the initial horizontal coordinatex
, vertical coordinatey
, and the movement flagmove
of the cursor.
This code segment enables the control of the cursor position on the screen using a joystick. When the user operates the joystick, the x
and y
values change based on the direction. The move
flag is then set to 1. Subsequently, when the move
flag is 1, the cursor position is updated, achieving the effect of moving the cursor.
/*Joystick*/
x += 1;
if(x > 226)x = 226;
move =1;
x -= 1;
if(x < 0)x = 0;
move =1;
y -= 1;
if(y < 0)y = 0;
move =1;
y += 1;
if(y > 224)y = 224;
move =1;
x = 70;
y = 120;
move =1;
if(move == 1){
move = 0;
3.4 Implementation Results
- Hardware Connection
- Display Effect
