Remote Power-On
1. Introduction to Luckfox PicoKVM Ext
1.1 Resource Overview
  1. USB-C Port: Connects to the motherboard USB header USB_P1
  2. USB-A Port: Connects to the motherboard USB header USB_P2
  3. IO Control Ribbon Connector
  4. Power Supply Switch: Allows switching between USB power and PCIe power
  5. PCIe Interface: Supports 12V power input
  6. Front Panel Ribbon Connector: Connects to the motherboard front panel and chassis panel
  7. Motherboard USB Header
1.2 IO Control Pin Description
1.3 Physical Dimensions
2. IO Control Pin Description
[danger]
Before powering on the device, carefully verify that all motherboard connections are correct. The manufacturer shall not be held liable for any damage to the motherboard or device caused by incorrect wiring or improper operation.
  1. Follow the video tutorial to properly mount and secure the Luckfox PicoKVM Ext onto the chassis motherboard.
2. Open the KVM Web Management Interface and click the Power button in the upper-left corner to perform a remote power-on operation.
