5. SPI
5.1 Introduction
  • SPI stands for Serial Peripheral Interface, which is a high-speed, full-duplex, synchronous communication bus.
  • It operates in a master-slave mode, where typically one master device corresponds to one or more slave devices. It requires 4 wires for bidirectional data transfer and can be reduced to 3 wires for unidirectional data transfer.
  • The SPI bus consists of four physical connections: two data lines, one clock line, and a slave select line.
    • MOSI (Master Output/Slave Input) – The line through which the Core3566 sends data to the device (sensor).
    • MISO (Master Input/Slave Output) – The line through which the device sends data to the Core3566.
    • SCLK (Clock) – The clock signal line.
    • SS/CS (Slave Select/Chip Select) – The line used to select the device to which data is being sent.
  • Core3566 has two SPI interfaces, namely SPI1 and SPI3.
5.2 Enabling the SPI Interface
  • The process of enabling the SPI interface is similar to I2C. Simply select SPI.
    ┌────────────┤ luckfox Software Configuration Tool (luckfox-config) ├────────────┐
    │ P1 SPI1 Enable/disable automatic loading of SPI1 kernel module │
    │ P2 SPI3 Enable/disable automatic loading of SPI3 kernel module │
    │ <Select> <Back> │
  • Use the ls command to check if the enablement was successful:
    linaro@linaro-alip:~$ ls /dev/spi*
    /dev/spidev1.0 /dev/spidev1.1
5.3 Hardware Connection
  • Pin connections for Core3566:
    1.5inch OLED ModuleCore3566 Board Physical Pin NumberFunction
    VCC3V3Power input
    GNDGNDPower ground
    DINSPI1_MOSIMaster Output/Slave Input
    CLKSPI1_CLKSPI Clock signal
    CSSPI1_CS0Chip select
    DCGPIO3_A3Data/Command select
    RSTGPIO3_C4Reset
  • Wiring Diagram.
5.4 Controlling with Python Program
  • Download the experiment code and run the program in the terminal:
    cd ~/OLED_1in5/
    sudo python3 OLED_1in5_spi.py
