Getting Started Tutorial
Introduction
LuckFox Pico 、Luckfox Pico Mini A/B and LuckFox Pico Plus are low-cost micro Linux development boards based on the Rockchip RV1103 chip, while LuckFox Pico Pro、LuckFox Pico Max and Luckfox Pico Ultra W are low-cost micro Linux development boards based on the Rockchip RV1106 chip. RV1103/RV1106 is a highly integrated IPC visual processing SoC designed for AI-related applications. It is built on a single-core ARM Cortex-A7 32-bit core with integrated NEON and FPU, and features a built-in NPU that supports INT4/INT8/INT16 mixed operations, with a computing power of up to 0.5 TOPs.
Furthermore, it features a new hardware-based ISP that supports various algorithm accelerators such as HDR, 3A, LSC, 3DNR, 2DNR, sharpening, haze removal, gamma correction, and more. Additionally, it has a built-in 16-bit DDR2 DRAM to maintain demanding memory bandwidth, as well as built-in POR, audio codec, and MAC PHY. In essence, the RV1103 is a powerful processor suitable for various AI application scenarios.
The development board supports multiple interfaces, including GPIO, UART, SPI, I2C, USB, etc., facilitating rapid development and debugging for developers.It's worth noting that the entire LuckFox Pico series development boards support both buildroot and Ubuntu 22.04 systems, allowing developers to choose the appropriate system based on project requirements, providing greater flexibility to meet specific application needs.
Product Parameters
Luckfox Pico | Luckfox Pico Mini A | Luckfox Pico Mini B | Luckfox Pico Plus | Luckfox Pico Pro | Luckfox Pico Max | Luckfox Pico Ultra | Luckfox Pico Ultra W | |
Chip | Rockchip RV1103 | RV1106G2 | Rockchip RV1106G3 | |||||
Processor | Cortex A7 1.2GHz | |||||||
Neural Network Processor (NPU) | 0.5 TOPS, supports int4, int8, int16 | |||||||
Image Processor (ISP) | Max input 4M @30fps | Max input 5M @30fps | ||||||
Memory | 64MB DDR2 | 128MB DDR3L | 256MB DDR3L | |||||
Wi-Fi+Bluetooth | No | 2.4GHz WiFi6 Bluetooth 5.2/BLE | ||||||
Camera Interface | MIPI CSI 2-lane | |||||||
DPI Interface | No | RGB666 | ||||||
POE Interface | No | IEEE 802.3af PoE | ||||||
Speaker interface | No | MX1.25mm | ||||||
USB | USB 2.0 Host/Device | |||||||
GPIO | 24 GPIO pins | 17 GPIO pins | 25 GPIO pins | 26 GPIO pins | 30 GPIO pins | |||
Ethernet | No | 10/100M Ethernet controller and embedded PHY | ||||||
Default Storage Medium | Micro SD Card | SPI NAND FLASH (128MB) | SPI NAND FLASH (256MB) | eMMC(8GB) |
