Product Introduction
1. Introduction
The Luckfox Omni3576 main control unit utilizes the Rockchip RK3576 processor, which is built on an advanced 8nm process technology. It features an octa-core 64-bit CPU (including 4×Cortex-A72@2.3GHz and 4×Cortex-A53@2.2GHz), an integrated ARM Mali-G52 MC3 GPU, and a built-in NPU with a performance of 6 TOPS. It supports various video input and output interfaces, offering strong computing and graphics processing capabilities, with support for 8GB of large memory, 2.4/5G Wi-Fi, and 4G wireless communication. It boasts rich interface expansions suitable for a wide range of applications, including IoT devices, smart audio, smart displays, industrial control, and educational equipment. The Luckfox Omni3576 supports Buildroot, Debian 12, Android 14, and Ubuntu 22.04 systems.
2. Specifications
| Core3576 | |||||||||
| CPU | ARM | 4×Cortex-A72@2.3GHz + 4×Cortex-A53@2.2GHz | |||||||
| GPU | ARM Mali-G52 MC3,supporting OpenGL ES 1.1/2.0/3.2、OpenCL 2.0、Vulkan 1.1 | ||||||||
| NPU | 6TOPS INT8,supportting INT4/INT8/INT16/FP16/BF16/TF32 | ||||||||
| VPU | Hardware Encoding:H.264、H.265,4K@60fps | Hardware Decoding:H.264、H.265、VP9、AV1、AVS2,8K@30fps 或 4K@120fps | |||||||
| RAM | 4/8GB LPDDR4 | ||||||||
| ROM | 0/32/64GB eMMC | ||||||||
| Omni3576 | |||||||||
| Function | Quantity | Specifications | |||||||
| WiFi | 1 | 2.4/5GHz WiFi6 | |||||||
| Bluetooth | 1 | Supports Wi-Fi 2.4G/5G, Bluetooth 5.0 | |||||||
| MIPI CSI | 2 | MIPI CSI 4-lanes, default supports IMX415 | |||||||
| MIPI DSI | 1 | MIPI DSI 4-lanes, default supports 1280x800 | |||||||
| HDMI TX | 1 | HDMI v2.1, supporting up to 4K@120Hz | |||||||
| DP TX | 1 | DP interface combined with USB 3.2 Gen 1, using Type-C; DisplayPort v1.4, supporting up to 4K@120Hz | |||||||
| Audio | 1 | Onboard Codec chip, supports MIC input and Speaker output | |||||||
| TF Card Slot | 1 | Supports TF cards, speeds up to 150MHz, supporting SDR104 mode | |||||||
| Ethernet | 2 | Supports 10/100/1000 Mbps data transmission rates | |||||||
| POE | 1 | IEEE 802.3af PoE | |||||||
| USB | 4 | USB 2.0 x 3, USB 3.2 Gen 1 port (5Gbps) × 1, USB Type-C (5Gbps/DP) × 1, supporting OTG and flashing | |||||||
| RTC | 1 | Onboard RTC chip and battery socket | |||||||
| M.2 Slot | 1 | M.2 M_KEY(PCIe NVMe SSD, supports 2242/2260/2280 specifications) | |||||||
| IR | 1 | Supports 38KHz infrared input | |||||||
| GPIO | 1 | 28 GPIO pins | |||||||
