Luckfox Pico RV1106
The Luckfox Pico RV1106 series includes five different board models, designed to meet the diverse needs of DIY enthusiasts and engineers. These users can take advantage of the rich community resources to gain insights and inspiration for their own projects. The Luckfox Pico Series User Manual includes schematics and a Software Development Kit (SDK), enabling users to understand the board’s internal workings and integrate it into their own designs.
Luckfox Pico Pro/Max
Overview:Supports SPI display interfaces and MIPI CSI camera input, with a standard stamp-hole form factor. Ideal for lightweight image capture and display applications.
| Luckfox Pico Pro | Luckfox Pico Max | |
| Chip | RV1106G2 | RV1106G3 |
| Processor | Cortex A7 1.2GHz | |
| NPU | 0.5TOPS, supports int4、in8、int16 | 1TOPS, supports int4、in8、int16 |
| ISP | Max input 5M @30fps | |
| Memory | 128MB DDR3L | 256MB DDR3L |
| Camera Interface | MIPI CSI 2-lane | |
| USB | USB 2.0 Host/Device | |
| GPIO | 26 个 GPIO pins | |
| Ethernet | 10/100M Ethernet controller and embedded PHY | |
| Default Storage Medium | SPI NAND FLASH(256MB) | |
Luckfox Pico Ultra Series
Overview:Supports Wi-Fi connectivity, audio input/output, camera capture, and RGB screen driving, making it suitable for wireless multimedia terminal scenarios.
| Luckfox Pico Ultra | Luckfox Pico Ultra W | Luckfox Pico Ultra B | Luckfox Pico Ultra BW | |
| Chip | RV1106G3 | RV1106G2 | ||
| Processor | Cortex A7 1.2GHz | |||
| NPU | 1TOPS, supports int4、in8、int16 | 0.5TOPS, supports int4、in8、int16 | ||
| ISP | Max input 5M @30fps | |||
| Memory | 256MB DDR3L | 128MB DDR3L | ||
| Wi-Fi+Bluetooth | / | 2.4GHz WiFi6 Bluetooth 5.2/BLE | / | 2.4GHz WiFi6 Bluetooth 5.2/BLE |
| Camera Interface | MIPI CSI 2-lane | |||
| DPI Interface | RGB666 | |||
| POE Interface | IEEE 802.3af PoE | |||
| Speaker interface | MX1.25mm | |||
| USB | USB 2.0 Host/Device | |||
| GPIO | 330 GPIO pins | |||
| Ethernet | 10/100M Ethernet controller and embedded PHY | |||
| Default Storage Medium | eMMC(8GB) | |||
Core1106 Series
Overview: Designed with a stamp-hole form factor, this series integrates CPU/NPU/GPU computing resources, and supports various high-speed peripheral interfaces. It serves as a powerful system core for modular expansion and broader applications.
Basic Specifications
| Core11060208 | Core11061208 | Core11060408 | Core11061408 | |
| SOC | RV1106G2 | RV1106G3 | ||
| NPU | 0.5 TOPS, supports int4, int8, int16 | 1 TOPS, supports int4, int8, int16 | ||
| VEPU | Supports H264/H265 video encoder | |||
| Memory | 128MB DDR3L | 256MB DDR3L | ||
| Core board size | 30 mm × 30 mm | |||
| Stamp pin | 112 Pin | |||
| Operating Temperature Range | -20~60 ℃ | |||
Functional Parameters
| Function | Quantity | Parameters | |||||||
| MIPI CSI | ≤2 | Supports 2 CSI-2 interfaces, each with 2 D-PHY v1.2 data lanes. These 2 interfaces can be combined into a single interface with 4 data lanes. | |||||||
| Display | 1 | 18-bit(RGB666) | |||||||
| USB | 1 | USB 2.0 Host/Device | |||||||
| Ethernet | 1 | 10/100M Ethernet controller and embedded PHY | |||||||
| Audio | 1 | LINEOUT | |||||||
| 2 | Analog differential MIC interface. | ||||||||
| I2S | ≤3 | Supports 8 TX lanes and 8 RX lanes. Supports 3 I2S modes (Standard I2S, Left-Justified, Right-Justified). Supports 4 PCM formats (Early mode, Late1 mode, Late2 mode, Late3 mode). Supports a maximum sampling rate of 192kHz. Supports audio resolution: 16 to 32 bits. | |||||||
| I2C | ≤5 | Supports 7-bit and 10-bit address modes. Standard mode data transfer rate: 100k bits/s, in fast mode: 400k bits/s. | |||||||
| SPI | ≤2 | Supports master and slave modes, with each interface supporting two chip selects. | |||||||
| SDIO | ≤2 | Compatible with SDIO 3.0 protocol, 4-bit mode. | |||||||
| ADC | ≤2 | Supports 2-channel 10-bit single-ended input SAR-ADC with a sampling rate of up to 1MS/s. | |||||||
| UART | ≤6 | Built-in 2-channel 64-bit FIFO, separately used for TX and RX. Supports 5-bit, 6-bit, 7-bit, and 8-bit serial data transmission and reception, with a baud rate of up to 4Mbps. | |||||||
| PWM | ≤12 | Embedded 32-bit timer/counter functionality. Supports capture mode. | |||||||
Luckfox-Pico-86-Panel
Overview: Features an integrated RGB display interface and industrial RS-485 communication, making it ideal for HMI (Human-Machine Interface) and industrial fieldbus communication applications.
| Luckfox-Pico-86-Panel-0408 | Luckfox-Pico-86-Panel-1408 | Luckfox-Pico-86-Panel-0208 | Luckfox-Pico-86-Panel-1208 | |
| NPU | 1 TOPS, supports INT4/INT8/INT16 | 0.5 TOPS, supports INT4/INT8/INT16 | ||
| VEPU | Supports H264/H265 video encoding | |||
| Wi-Fi + Bluetooth | / | 2.4GHz WiFi6 Bluetooth 5.2/BLE | / | 2.4GHz WiFi6 Bluetooth 5.2/BLE |
| Ethernet Port | 10/100M Ethernet controller and embedded PHY | |||
| Audio Interface | 1 x SMT microphone 1 x Microphone expansion interface (MX1.25mm-2P) | |||
| USB | 1 x USB Device | |||
| RTC | 1 x RTC coin cell battery holder | |||
| Relay Interface | 2 x Common terminal/Normally open terminal | |||
| RS485 | 1 x RS485 | |||
| Power Interface | DC 6V~30V wide voltage range input | |||
Luckfox Pico Pi Series
Overview: Integrates 4G dial-up connectivity, audio codec interface, and MIPI camera input, supporting remote communication and local audio processing in various application scenarios.
| Luckfox Pico Pi A | Luckfox Pico Pi A W | Luckfox Pico Pi B | Luckfox Pico Pi B W | |
| SOC | RV1106G3 | RV1106G2 | ||
| NPU | 1 TOPS,supports int4、int8、int16 | 0.5 TOPS,supports int4、int8、int16 | ||
| ISP | Maximum 5M @30fps input | |||
| Default Storage | eMMC(8GB) | |||
| POE Port | IEEE 802.3af PoE | |||
| Camera Interface | 1 x MIPI CSI 2-lane | |||
| Audio | 1 x Surface-mount microphone 1 x Microphone expansion port (MX1.25mm-2P) 1 x 3.5mm audio output | |||
| USB | 1 x USB Device 4 x USB HOST 2.0 (HUB expansion) | |||
| RTC | 1 x RTC Port(SH1.0-2P) | |||
| Storage Expansion | 1 x MicroSD slot (storage-only, no system boot support) | |||
| Mobile Connectivity | 1 x Nano SIM slot 1 x 4G module M.2 slot (supports SIM7600G-H-M.2 4G module) | |||
| GPIO | Based on Raspberry Pi 40Pinout | |||
