Luckfox Pico Ultra W
Product Introduction
Luckfox Pico Ultra W are low-cost micro Linux development boards based on the Rockchip RV1106 chip. RV1106 is a highly integrated IPC visual processing SoC designed for AI-related applications. It is built on a single-core ARM Cortex-A7 32-bit core with integrated NEON and FPU, and features a built-in NPU that supports INT4/INT8/INT16 mixed operations, with a computing power of up to 1 TOPs.
Furthermore, it features a new hardware-based ISP that supports various algorithm accelerators such as HDR, 3A, LSC, 3DNR, 2DNR, sharpening, haze removal, gamma correction, and more. Additionally, it has a built-in 16-bit DDR3L DRAM to maintain demanding memory bandwidth, as well as built-in POR, audio codec, and MAC PHY.
The development board supports multiple interfaces, including GPIO, UART, SPI, I2C, USB, etc., facilitating rapid development and debugging for developers.It's worth noting that the entire LuckFox Pico series development boards support both buildroot systems, allowing developers to choose the appropriate system based on project requirements, providing greater flexibility to meet specific application needs.
Product Parameters
Luckfox Pico UltraLuckfox Pico Ultra WLuckfox Pico Ultra BLuckfox Pico Ultra BW
ChipRV1106G3RV1106G2
ProcessorCortex A7 1.2GHz
NPU1TOPS, supports int4、in8、int160.5TOPS, supports int4、in8、int16
ISPMax input 5M @30fps
Memory256MB DDR3L128MB DDR3L
Wi-Fi+Bluetooth/2.4GHz WiFi6 Bluetooth 5.2/BLE/2.4GHz WiFi6 Bluetooth 5.2/BLE
Camera InterfaceMIPI CSI 2-lane
DPI InterfaceRGB666
POE InterfaceIEEE 802.3af PoE
Speaker interfaceMX1.25mm
USBUSB 2.0 Host/Device
GPIO33 GPIO pins
Ethernet10/100M Ethernet controller and embedded PHY
Default Storage MediumeMMC(8GB)
