Version introduction
Introduction
LuckFox Pico 、Luckfox Pico Mini A/B and LuckFox Pico Plus are low-cost micro Linux development boards based on the Rockchip RV1103 chip, while LuckFox Pico Pro and LuckFox Pico Max are low-cost micro Linux development boards based on the Rockchip RV1106 chip. RV1103/RV1106 is a highly integrated IPC visual processing SoC designed for AI-related applications. It is built on a single-core ARM Cortex-A7 32-bit core with integrated NEON and FPU, and features a built-in NPU that supports INT4/INT8/INT16 mixed operations, with a computing power of up to 0.5 TOPs.
Furthermore, it features a new hardware-based ISP that supports various algorithm accelerators such as HDR, 3A, LSC, 3DNR, 2DNR, sharpening, haze removal, gamma correction, and more. Additionally, it has a built-in 16-bit DDR2 DRAM to maintain demanding memory bandwidth, as well as built-in POR, audio codec, and MAC PHY. In essence, the RV1103 is a powerful processor suitable for various AI application scenarios.
This development board is suitable for applications in various scenarios, including but not limited to:
- Smart home devices
- Industrial automation equipment
- Robots and drones
- Intelligent monitoring devices
- Intelligent transportation equipment
- Smart medical devices
The development board supports multiple interfaces, including GPIO, UART, SPI, I2C, USB, etc., facilitating rapid development and debugging for developers.
Product Parameters
Luckfox Pico | Luckfox Pico Mini A | Luckfox Pico Mini B | Luckfox Pico Plus | Luckfox Pico Pro | Luckfox Pico Max | |
Chip | Rockchip RV1103 | Rockchip RV1106 | ||||
Processor | Cortex A7 1.2GHz | |||||
Neural Network Processor (NPU) | 0.5 TOPS, supports int4, int8, int16 | |||||
Image Processor (ISP) | Max input 4M @30fps | Max input 5M @30fps | ||||
Memory | 64MB DDR2 | 128MB DDR3L | 256MB DDR3L | |||
Camera Interface | MIPI CSI 2-lane | |||||
USB | USB 2.0 Host/Device | USB 2.0 Host/Device | USB 2.0 Host/Device | |||
GPIO | 24 GPIO pins | 17 GPIO pins | 25 GPIO pins | 26 GPIO pins | ||
Ethernet | No | 10/100M Ethernet controller and embedded PHY | ||||
Default Storage Medium | Micro SD Card | SPI NAND FLASH (128MB) | SPI NAND FLASH (256MB) | |||
Error Message | The `style` prop expects a mapping from style properties to values, not a string. |
