PWM
In this chapter, we will learn how to use PWM at the application level.
Sample program : Code.zip
1. PWM
PWM, which stands for Pulse Width Modulation, is a technique used to generate analog-like signals by controlling the pulse width of a digital signal. It is commonly used in embedded systems and electronic devices for applications such as motor speed control, LED brightness control, audio signal generation, and more.
In the Linux operating system, PWM devices are typically managed and configured using the sysfs file system, and their device directories are usually located under the /sys/class/pwm/ directory.
2. PWM Control (Shell)
2.1 Pin Distribution
LuckFox Pico Pro/Max Diagram:
2.2 Enable PWM
Use luckfox-config to enable the relevant configuration:
- Use the ↑ and ↓ keys on the keyboard to navigate through menu items, Enter to select, ←, →, or Tab to choose between the OK and cancel buttons, Esc to cancel and go back, and the spacebar to select options. Any changes will take effect after a reboot. Note: When logging in via ADB, arrow keys and Tab cannot be used; only numeric keys can be used to select options, and Enter to confirm.
Open the luckfox-config tool in the terminal:
luckfox-configSelect Advanced Options:
Select PWM:
Select the PWM interface you want to enable, here we use PWM7_M1 as an example:
Choose
enable, and after selecting, pressEnterto confirm, then pressEscto exit:Reboot the development board.
reboot
2.3 Device Directory
Under the /sys/class/pwm/ directory, each PWM device has its own separate subdirectory, usually named in the form pwmchipX, where X is the PWM device number. You can check this using the following command:
[root@luckfox root]$ ls -l /sys/class/pwm
total 0
lrwxrwxrwx 1 root root 0 Jan 1 1970 pwmchip1 -> ../../devices/platform/ff350010.pwm/pwm/pwmchip1
lrwxrwxrwx 1 root root 0 Jun 13 13:28 pwmchip7 -> ../../devices/platform/ff360030.pwm/pwm/pwmchip7
2.4 Device Properties
After successfully exporting a channel of PWM, a subdirectory corresponding to that channel is created within the PWM's device directory. This subdirectory contains property files specific to that channel. Users can configure and control various parameters of a specific PWM channel by modifying the contents of these files, enabling precise control over the characteristics of the PWM signal. This provides a convenient interface for users to interact with the PWM hardware and adjust the PWM signal's properties.
View the property files for a single channel, such as PWM10:
# ls /sys/class/pwm/pwmchip10/pwm0/
uevent capture duty_cycle output_type
polarity enable power periodProperty Files
By using these property files, you can easily configure and control the PWM channel to suit different application scenarios and requirements. Some key properties include:
enable: Used to enable or disable the PWM channel.period: Sets the period time of the PWM signal.duty_cycle: Sets the duty cycle of the PWM signal.polarity: Configures the polarity of the PWM signal.power/control: Enables or disables power management for the PWM channel (typically used for power-saving modes).
2.5 Controlling PWM
Test PWM. Export PWM10_M1 (GPIO1_C6_d) to user space.
echo 0 > /sys/class/pwm/pwmchip10/exportSet the PWM period in nanoseconds. For example, for a 1KHz frequency, the period is 1000000ns (Note: ensure that the period value is greater than or equal to the duty_cycle value).
echo 1000000 > /sys/class/pwm/pwmchip10/pwm0/periodSet the duty cycle (must be less than or equal to the period).
echo 100000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 200000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 300000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 400000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 500000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 600000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 700000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 800000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 900000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 1000000 > /sys/class/pwm/pwmchip10/pwm0/duty_cycle
echo 0 > /sys/class/pwm/pwmchip10/pwm0/duty_cycleSet PWM polarity to normal or inverted.
echo "normal" > /sys/class/pwm/pwmchip1/pwm0/polarity
echo "inversed" > /sys/class/pwm/pwmchip1/pwm0/polarityEnable and disable PWM.
echo 1 > /sys/class/pwm/pwmchip1/pwm0/enable
echo 0 > /sys/class/pwm/pwmchip1/pwm0/enableUnexport PWM from user space.
echo 0 > /sys/class/pwm/pwmchip10/unexport
3. PWM Control (Python Program)
In the previous section, we demonstrated how to control devices by using the echo command to modify device files. Next, we will implement PWM control using a Python program.
3.1 Sample Program
With the following program, PWM10 output can be controlled.
from periphery import PWM
import time
pwm = PWM(10, 0)
pwm.frequency = 1000
pwm.duty_cycle = 0
pwm.polarity = "normal"
pwm.enable()
direction = 1
while True:
pwm.duty_cycle += 0.01 * direction
pwm.duty_cycle = round(pwm.duty_cycle, 2)
if pwm.duty_cycle == 1.0:
direction = -1
elif pwm.duty_cycle == 0.0:
direction = 1
time.sleep(0.05)
except KeyboardInterrupt:
pass
finally:
pwm.close()
3.2 Open PWM Device
This code segment uses the PWM class from the periphery library to create a PWM object. In this example, the PWM object is initialized for PWM10.
pwm = PWM(10, 0)
3.3 Configure PWM
In this code segment, some properties of the previously created PWM object are configured. The PWM frequency is set to 1000 Hz, the polarity is set to "normal," and the duty cycle is initialized to 0.
pwm.duty_cycle = 0
3.4 PWM Output
This code segment implements a simple PWM output. By continuously adjusting the duty cycle in a loop, a breathing effect is achieved. The pwm.duty_cycle is increased by 0.01 each time (adjustable as needed), and the round function is used to keep it to two decimal places. When reaching the maximum or minimum value, the direction is reversed. After each PWM value update, the breathing speed is controlled using time.sleep.
while True:
direction = -1
direction = 1
print(pwm.duty_cycle)
time.sleep(0.05)
3.5 Running the Program
Use the vi tool in the terminal to create a Python file, paste the Python program, and save it.
# nano pwm.pyRun the program.
# python3 pwm.pyExperimental Observations
Control PWM10 to realize breathing light
4. PWM Control (C Program)
In the previous section, we demonstrated how to control PWM using the echo command and a Python program. Additionally, you can also use the vi editor to modify files, but be cautious about user permissions when making modifications. Furthermore, we can utilize C library functions or system calls to read and write device files for device control. Please note that to run programs on specific embedded systems, it is typically necessary to use cross-compilation tools to compile the code into an executable file that can run on the target development board. Let's explore the specific implementation steps together.
4.1 Complete Code
With the following program, you can control PWM output.
#include <string.h>
#define PWM_PATH "/sys/class/pwm/pwmchip10"
#define PERIOD_NS 1000000
#define MIN_DUTY_CYCLE_NS 0
#define MAX_DUTY_CYCLE_NS 1000000
FILE *pwm_export = fopen(PWM_PATH "/export", "w");
if (!pwm_export) {
perror("Failed to open PWM export");
return 1;
fprintf(pwm_export, "0");
fclose(pwm_export);
FILE *period_file = fopen(PWM_PATH "/pwm0/period", "w");
if (!period_file) {
perror("Failed to open PWM period");
return 1;
fprintf(period_file, "%d", PERIOD_NS);
fclose(period_file);
FILE *enable_file = fopen(PWM_PATH "/pwm0/enable", "w");
if (!enable_file) {
perror("Failed to open PWM enable");
return 1;
fprintf(enable_file, "1");
fclose(enable_file);
int direction = 1; // 1 for increasing duty cycle, -1 for decreasing
int duty_cycle_ns = 0;
while (1) {
duty_cycle_ns += 10000 * direction;
if(duty_cycle_ns == MAX_DUTY_CYCLE_NS)
direction = -1;
else if(duty_cycle_ns == MIN_DUTY_CYCLE_NS)
direction = 1;
FILE *duty_cycle_file = fopen(PWM_PATH "/pwm0/duty_cycle", "w");
if (!duty_cycle_file) {
perror("Failed to open PWM duty cycle");
return 1;
fprintf(duty_cycle_file, "%d", duty_cycle_ns);
fclose(duty_cycle_file);
usleep(50000); // Adjust this value for desired breathing speed
FILE *pwm_unexport = fopen(PWM_PATH "/unexport", "w");
if (!pwm_unexport) {
perror("Failed to open PWM unexport");
return 1;
fprintf(pwm_unexport, "0");
fclose(pwm_unexport);
4.2 Export PWM Channel to User Space
This code exports the specified PWM channel for user space control by writing the device index (usually 0) to /sys/class/pwm/pwmchip10/export.
if (!pwm_export) {
return 1;
fclose(pwm_export);
4.3 Set PWM Period
This code sets the PWM period to 1KHZ by writing the period value "1000000" (in nanoseconds) to /sys/class/pwm/pwmchip10/pwm0/period.
if (!period_file) {
return 1;
4.4 Enable PWM
This code enables the PWM signal output by writing the value "1" to the /sys/class/pwm/pwmchip10/pwm0/enable file.
if (!enable_file) {
return 1;
4.5 Implement PWM-Based Breathing LED Effect
This code opens the /sys/class/pwm/pwmchip10/pwm0/duty_cycle file and achieves a breathing LED effect by continuously changing the duty_cycle_ns variable from 0% to 100%, and then from 100% to 0%. The duty_cycle_ns variable's changes are between 0 and 1000000, controlling the duty cycle variation. When the duty cycle reaches its minimum or maximum value, it reverses direction to create a back-and-forth motion. Additionally, the usleep(50000) function is used to control the speed of the breathing LED. You can adjust this value as needed to change the breathing speed.
while (1) {
direction = -1;
direction = 1;
return 1;
4.6 Unexport PWM Channel from User Space
This code cancels the export of the specified PWM channel to user space by writing the device index to /sys/class/pwm/pwmchip10/unexport.
return 1;
4.7 Cross-Compilation
PATHenvironment variable so that you can use the cross-compilation tool from anywhere. You can add the following line to your shell configuration file (usually~/.bashrcor~/.bash_profileor~/.zshrc, depending on your shell). Note that the path afterPATH=should point to the directory where the cross-compilation tool is located.gcc path
<SDK Directory>/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf-gccOpen the shell configuration file.
nano ~/.bashrcAdd the path of the cross-compilation tool to the system's PATH environment variable. Replace
<SDK Directory>with your own SDK path, such as/home/luckfox/luckfox-pico/.export PATH=<SDK Directory>/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin:$PATHReload the shell configuration file to apply the changes:
arm-rockchip830-linux-uclibcgnueabihf-gcc pwm.c -o pwmAfter successful cross-compilation, an executable file that can run on the development board will be generated in the current directory.
#ls
pwm pwm.c
4.8 Running the Program
File Transfer
First, transfer the
pwmprogram from the virtual machine to Windows, and then transfer it to the development board via TFTP or ADB. Here are the steps to transfer the file from Windows to the development board using ADB:adb push path_to_file destination_on_development_board
eg: (Transferring the `pwm` file from the current directory to the root directory of the development board)
adb push pwm /Running the Program
Modify the permissions of the
pwmfile and then run the program:# chmod 777 pwm
# ./pwmExperimental Observations
