7″ DSI Touchscreen
1. Introduce
7'' DSI Touchscreen is a capacitive touchscreen with a resolution of 800x480 and a viewing angle of 170°. It supports multiple operating systems and does not require driver installation, meeting various application needs.
2. Product parameters
ProjectDescribeUnit
Model7'' DSI Touchscreen/
Size7.0Inch
Viewing Angle170Deg
Resolution800x480Pixels
Product Size192.96 (H) × 110.76 (V)mm
Display Area154.88 (H) × 86.72 (V)mm
Color Gamut50%NTSC
Maximum Brightness350cd/m²
Constrast1000:1/
Backlight ControlSoftware Dimming/
Refresh Rate60Hz
Power2.5Watt
3. Use with Raspberry Pi
3.1 Hardware Connection
  1. Connect FPC cable to the display.
  2. Fix the Raspberry Pi by screws,connect the FPC cable.
  3. Connect the power supply.(Standard version)
  4. For the version with case: attach the case and fix it.(with case version)
3.2 Software Setting
Support Raspberry Pi OS/Ubuntu/Kali and Retropie systems.
  1. Connect TF card to PC
  2. Please click Raspberry Pi official website to download the newest image.
  3. Open the Raspberry Pi Imager, select the TF card where the image will be written (Note: It is best to remove other USB devices to prevent accidental erasure of their files).
  4. Pre-configure the system, hold down CTRL+SHIFT+X (or click the small gear icon in the bottom right corner), then click save after settings are completed
  5. Click the burn button to write data to the TF card.
  6. After burning is complete, open the 'config.txt' file under the '/boot/firmware/' directory, add the following statement to the end of the 'config.txt' file, then save and exit.
    Note: Due to the Pi5/CM5/CM4/CM3+/CM3 having two MIPI DSI interfaces, please ensure to use the correct DSI interface and command. DSI1 is recommended by default.
    dtoverlay=vc4-kms-v3d
    #DSI1 Use
    dtoverlay=vc4-kms-dsi-7inch
    #DSI0 Use (Only Pi5/CM4)
    #dtoverlay=vc4-kms-dsi-7inch,dsi0
  7. Insert the TF card into the Raspberry Pi, power it on, and after waiting for a few seconds, the screen should display normally.
3.3 Adjust Backlight Brightness
GUI interface dimming
  • 1.Open the "Screen Configuration" application;
  • 2.Go to "Screen" -> "DSI-2" -> "Brightness", check the backlight brightness you need to set, and finally click "Apply" to complete the backlight setting.
Command line dimming
3.4 Touchscreen Rotation
Bookworm system
GUI interface rotation
  1. Open "Screen Configuration" application:
  2. Go to "Screen"->"DSI-1"->"Touchscreen", check "6-0038 generic ft5x06(79)"
  3. Click “Apply” and close the current window. Reboot according to the pop-up prompts, then the touchscreen selection is complete.
  4. Go to "Screen" -> "DSI-1" -> "Orientation," check the direction you want to rotate, and finally click "Apply" to complete the synchronized rotation of the display and touch.
Lite version rotation
  1. Open cmdline.txt file
  2. To add the display rotation command at the beginning of the cmdline.txt file on a Raspberry Pi, simply add display_rotate=<angle>.( Note that the command needs to be placed on the same line, with each command separated by a space.)
#Display rotation 90 degrees
video=DSI-1:720x1280M@60,rotate=90
#Display rotation 180 degrees
video=DSI-1:720x1280M@60,rotate=180
#Display rotation 270 degrees
video=DSI-1:720x1280M@60,rotate=270
Note:
    1. If you are using Pi5/CM5, the actually recognized DSI display number will prevail, for example DSI-2.
    1. Unable to rotate DSI monitor and HDMI monitor separately using cmdline.txt. When you use both DSI and HDMI simultaneously, they share the same rotation value.
Bullseye/Buster system
  2. Go to "Screen"->"DSI-1"->"Orientation", select the rotation direction, and then click on "Apply".
    sudo nano /boot/cmdline.txt
  2. At the beginning of the cmdline.txt file, add the command corresponding to the angle of “display rotation”( Note that the command needs to be placed on the same line, with each command separated by a space.)
Note:
    1. If you are using CM4, the actually recognized DSI display number will prevail, for example DSI-2.
Stretch/Jessie system
For some older systems, which do not use the vc4-kms-v3d or vc4-fkms-v3d driver modes, the display rotation method is as follows:
  1. Add statements to the config.txt file (the config file is located in the root directory of the TF card, i.e. /boot):
display_rotate=1 #1:90;2: 180; 3: 270
  1. Save and reboot
sudo reboot
3.5 Touch Rotation
Bookworm touch rotation
If you use the graphical interface for rotation, you can check "Touchscreen" in the Screen Layout Editor window to synchronize the touch rotation. Refer to the earlier methods for display rotation. For the command-line rotation method, refer to the following text:
  1. Create a new file named 99-waveshare-touch.rules
  2. Edit the file:
    #90°:
    #180°:
    #ENV{ID_INPUT_TOUCHSCREEN}=="1", ENV{LIBINPUT_CALIBRATION_MATRIX}="-1 0 1 0 -1 1"
    #270°:
    #ENV{ID_INPUT_TOUCHSCREEN}=="1", ENV{LIBINPUT_CALIBRATION_MATRIX}="0 1 0 -1 0 1"
  3. Save and reboot
    sudo reboot
Bullseye/Buster touch rotation
After display rotation in Bullseye/Buster and some other systems, the touch direction may not be consistent. You need to follow the steps below to rotate the touch accordingly:
  1. Install libinput
       sudo apt-get install xserver-xorg-input-libinput
    If you are using an Ubuntu system or Jetson Nano, the installation command is:
    sudo apt install xserver-xorg-input-synaptics
  2. Create the xorg.conf.d directory under /etc/X11/ (if the directory already exists, proceed directly to step 3).
    sudo mkdir /etc/X11/xorg.conf.d
  3. Copy the 40-libinput.conf file to the directory you just created.
    sudo cp /usr/share/X11/xorg.conf.d/40-libinput.conf /etc/X11/xorg.conf.d/
  4. Edit this file
    sudo nano /etc/X11/xorg.conf.d/40-libinput.conf
    #Locate the touchscreen section, add the corresponding rotation angle command inside, and then save it.
    #90°Right touch rotation:
    Option "CalibrationMatrix" "0 1 0 -1 0 1 0 0 1"
    #180° Inverted touch rotation:
    #Option "CalibrationMatrix" "-1 0 1 0 -1 1 0 0 1"
    #270° Left touch rotation:
    #Option "CalibrationMatrix" "0 -1 1 1 0 0 0 0 1"
    In a location similar to the one shown in the image:
  5. Save and reboot
    sudo reboot
3.6 Use Touchscreen Virtual Keyboard
When connecting to the touch display, the on-screen keyboard will automatically appear if text input is possible, and it will automatically hide if text input is not possible.
For applications that do not support automatic text input detection, you can manually display or hide the on-screen keyboard by clicking the keyboard icon at the far right of the task bar.
You can also permanently set the display or hide the screen keyboard through the "Display" option under "Raspberry Pi Configuration" or through the "Display" section in raspi-config.
Note:
For versions of Raspberry Pi OS before Bookworm, use matchbox-keyboard. If you are using the wayfire desktop compositor, use wvkbd.
3.7 Touch Mode Selection
The Bookworm system supports two touch modes, which can be switched in the Screen Configuration > Touchscreen menu:
*1.Mouse Emulation (default)
Supports double-click
Does not support swipe page and multi-touch functions
*2.Multitouch
Supports swiping pages
Does not support double-click and right-click long press functions
Note: This mode is suitable for touch-optimized scenarios, such as web browsing and scrolling lists.
Resource
Q: Does this screen turn off automatically, or do I need to execute a command to do so?
A: It depends on the system. If the system has hibernation, the screen will be black. If it is the latest official system Bookworm for Raspberry Pi, it does not have hibernation by default.
