SDK Device Tree Overview
1. Introduction to Device Tree
The Device Tree is a mechanism used in the Linux kernel to describe board-level hardware information. It is written in text format, typically using the .dts (Device Tree Source) or .dtsi (Device Tree Source Include) file extensions. The .dts file defines specific hardware device information, while the .dtsi file is used to extract common device or platform configurations that are referenced by .dts files.
For Luckfox Pico, the device tree files are located in the following directory of the SDK: luckfox-pico SDK/sysdrv/source/kernel/arch/arm/boot/dts
During the build process, .dts and .dtsi files are compiled into binary .dtb (Device Tree Blob) files. At system startup, U-Boot loads the .dtb file into memory. The kernel then parses this file during boot to initialize hardware, load drivers, and register device nodes based on the hardware information it contains.
It is important to note that starting from Linux kernel 4.4, a Dynamic Device Tree mechanism was introduced. This allows parts of the .dtb configuration to be modified or overridden at runtime. Kernel drivers can adapt dynamically to the new configuration instead of relying solely on the statically loaded .dtb during boot.
2. Device Tree Configuration Overview
During the image build phase for Luckfox Pico, you must first select the appropriate board support file:
The board support file information is symbolically linked to
<luckfox-pico SDK>/.BoardConfig.mk. -
The board support file defines the .dts file corresponding to the specific Luckfox Pico model. For models with common hardware designs, their .dts files may include a shared .dtsi file to simplify centralized configuration management.
The .dts and .dtsi files corresponding to different models are listed below:
| 型号 | .dts | .dtsi |
| Luckfox Pico | rv1103g-luckfox-pico.dts | rv1103-luckfox-pico-ipc.dtsi |
| Luckfox Pico mini a | rv1103g-luckfox-pico-mini-a.dts | rv1103-luckfox-pico-ipc.dtsi |
| Luckfox Pico mini b | rv1103g-luckfox-pico-mini-b.dts | rv1103-luckfox-pico-ipc.dtsi |
| Luckfox Pico plus | rv1103g-luckfox-pico-plus.dts | rv1103-luckfox-pico-ipc.dtsi |
| Luckfox Pico pro/max | rv1106g-luckfox-pico-pro-max.dts | rv1106-luckfox-pico-pro-max-ipc.dtsi |
| Luckfox Pico ultra | rv1106g-luckfox-pico-ultra.dts | rv1106-luckfox-pico-ultra-ipc.dtsi |
| Luckfox Pico ultra W | rv1106g-luckfox-pico-ultra-w.dts | rv1106-luckfox-pico-ultra-ipc.dtsi |
| Luckfox Pico Pi A/B | rv1106g-luckfox-pico-pi.dts | rv1106-luckfox-pico-pi-ipc.dtsi |
| Luckfox Pico Pico Pi A/B W | rv1106g-luckfox-pico-pi-w.dts | rv1106-luckfox-pico-pi-ipc.dtsi |
| Luckfox-Pico-86-Panel-0208/0408 | rv1106g-luckfox-pico-86panel.dts | rv1106-luckfox-pico-86panel-ipc.dtsi |
| Luckfox-Pico-86-Panel-1208/1408 | rv1106g-luckfox-pico-86panel-w.dts | rv1106-luckfox-pico-86panel-ipc.dtsi |
3. Device Tree Configuration
3.1 Device Tree File Structure
For Luckfox Pico, the basic device tree configurations related to the RV1103 / RV1106 chips—such as rv1106.dtsi, rv1106-pinctrl.dtsi, etc.—are provided by Rockchip. Based on the hardware resources available on the Luckfox Pico, the default configurations are set in .dtsi files, while model-specific hardware information is defined in .dts files.
- The configurations in .dts files have the highest priority and can override settings in the .dtsi files. You can reference nodes from .dtsi and either modify their properties or recreate them entirely.
- For easier editing, the .dts file corresponding to the selected board support package is symlinked to
<luckfox-pico SDK>/config/dts_configafter running ./build.sh. Normally, you only need to edit the .dts file to configure hardware features—.dtsi files should not be modified.
3.2 常用配置
3.2.1 GPIO Configuration
Pins are configured as GPIO by default. The high or low output levels can be set using sysfs, but default pull-up or pull-down configurations must be done through the device tree or by writing to registers. To configure gpio1 pc7 as a pull-up by default, add the following to <luckfox-pico SDK>/config/dts_config:
gpio1pc7:gpio1pc7 {
pinctrl-0 = <&gpio1_pc7>;
regulator-name = "gpio1_pc7";
regulator-always-on;
gpio1-pc7 {
gpio1_pc7:gpio1-pc7 {
gpio1pc7represents the newly created node, which must be placed under the existing root node; a new root node cannot be created independently.other datarepresents the default configuration for Luckfox Pico's model and compatible properties.pcfg_pull_uprepresents the default pull-up,pcfg_pull_downrepresents the default pull-down, andpcfg_pull_nonerepresents no pull-up or pull-down.
3.2.2 PWM Configuration
PWM functionality can only be used by one pin at a time. For example, the pins corresponding to PWM1M0 and PWM1_M1 cannot be used simultaneously. The pin usage is controlled through the pinctrl attribute. To enable PWM1M0, add the following to <Luckfox-pico SDK>/config/dts_config:
&pwm1 {
status = "okay";
pinctrl-0 = <&pwm1m0_pins>;
&pwm1refers to the node, based onrv1106.dtsi.&pwm1m0_pinsrefers to the pinctrl node containing the pin and multiplex mode information, based onrv1106-pinctrl.dtsi.- Since PWM's frequency and duty cycle can be set using sysfs, the device tree configuration for PWM only enables the feature.
3.2.3 UART Configuration
UART functionality can only be used by one set of pins at a time. For example, the pin sets for UART1M0 and UART1M1 cannot be used together, and the pins within the set cannot be split. Pin usage is controlled through the pinctrl attribute. To enable UART1M0, add the following to <Luckfox-pico SDK>/config/dts_config:
&uart1 {
status = "okay";
pinctrl-0 = <&uart1m0_xfer>;
&uart1refers to the node, based onrv1106.dtsi.&uart1m0_xferrefers to the pinctrl node containing pin and multiplex mode information, based onrv1106-pinctrl.dtsi.- If flow control is needed, ensure the corresponding UART group has flow control pins, and add the necessary
ctsnandrtsnpin information to thepinctrl-0attribute.
3.2.4 I2C Configuration
I2C functionality can only be used by one set of pins at a time. For example, I2C0M0 and I2C0M1 cannot be used simultaneously, and the pins within the set cannot be split. Pin usage is controlled through the pinctrl attribute. To enable I2C0M0, add the following to <Luckfox-pico SDK>/config/dts_config:
&i2c0 {
status = "okay";
pinctrl-0 = <&i2c0m0_xfer>;
clock-frequency = <100000>;
&i2c0refers to the node, based onrv1106.dtsi.&i2c0m0_xferrefers to the pinctrl node containing pin and multiplex mode information, based onrv1106-pinctrl.dtsi.- The
clock-frequencyattribute sets the I2C clock frequency in Hz. You can adjust this according to actual needs, with the default I2C frequency set to 100000 (100kHz) in standard mode.
3.2.5 SPI Configuration
SPI functionality can only be used by one set of pins at a time. For example, SPI0M0 and SPI0M1 cannot be used together, and the pins within the set cannot be split. However, not all pins within the same SPI group must be used (e.g., only enabling CLK and MISO). Pin usage is controlled through the pinctrl attribute. If only the CLK and MOSI pins are to be enabled for SPI0M0, add the following to <Luckfox-pico SDK>/config/dts_config:
&spi0 {
status = "okay";
spidev@0 {
status = "okay";
reg = <0>;
fbtft@0 {
status = "disabled";
&spi0refers to the node, based onrv1106.dtsi. -
pinctrl-0refers to the node in the corresponding Luckfox Pico model's.dtsifile. The distinction fromrv1106-pinctrl.dtsiis that the pins are separated for easier configuration. -
The
spi-max-frequencyattribute sets the SPI clock frequency in Hz. You can adjust this according to actual needs, with the default SPI frequency set to 50 MHz. -
spidev@0refers to a child node in.dtsiused for SPI communication with the main device. -
fbtft@0refers to an FB device node in.dtsi, which should not be enabled together withspidev@0. If thefbtft@0node does not exist in the corresponding.dtsi, this configuration will have no effect. -
The
pinctrl/spi0node configures the pinsspi0m0_clk,spi0m0_mosi,spi0m0_miso, andspi0m0_cs0, but onlyspi0m0_clkandspi0m0_mosiare used. Unused pins will not be enabled for SPI functionality.
/* This pinctrl node has already been defined in the .dtsi file and does not need to be added in the .dts file */
spi0 {
spi0m0_clk: spi0m0-clk {
spi0m0_mosi: spi0m0-mosi {
spi0m0_miso: spi0m0-miso {
spi0m0_cs0: spi0m0-cs0 {
3.2.6 RGB Configuration
Luckfox Pico Ultra / Ultra W supports driving an RGB interface LCD screen, which requires multiple pins. Ensure that all the required pins are not configured for other functions before enabling the RGB interface. To configure the Luckfox Pico Ultra to drive the LF40-720720-ARK screen, add the following to <Luckfox-pico SDK>/config/dts_config:
&rgb{
status = "okay";
pinctrl-0 = <&lcd_pins>;
&panel{
display-timings {
timing0:timing0 {
clock-frequency = <30000000>;
hactive = <720>;
vactive = <720>;
hback-porch = <44>;
hfront-porch = <46>;
vback-porch = <18>;
vfront-porch = <16>;
hsync-len = <2>;
vsync-len = <2>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
pixelclk-active = <1>;
&rgbrefers to the referenced node, with the default attribute configuration found in the corresponding Luckfox Pico model's.dtsiandrv1106.dtsi. If the RGB interface is not needed, change thestatusattribute todisabled.&timing0refers to the timing information of the screen, which should be configured according to the screen's specifications.- For more configuration details, refer to the RGB section.
3.2.7 TouchScreen Configuration
Luckfox Pico Ultra / Luckfox Pico Ultra W support controlling the touchscreen via the I2C interface. A sub-node needs to be added to the I2C3 node to configure the touchscreen. For example, to configure the Luckfox Pico Ultra using I2C3 to drive the GT911 touchscreen chip on the LF40-720720-ARK screen, add the following to <Luckfox-pico SDK>/config/dts_config:
&i2c3 {
status = "okay";
pinctrl-0 = <&i2c3m2_xfer &tp_rst &tp_irq>;
GT911:touchscreen {
compatible = "goodix,gt911";
reg = <0x14>;
interrupt-parent = <&gpio0>;
interrupts = <RK_PA3 IRQ_TYPE_EDGE_FALLING>;
reset-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>;
GT911:touchscreenrepresents the created touchscreen sub-node. The related attribute configurations should be set according to the touchscreen specifications and the matching Goodix driver. -
pinctrl-0configures the I2C pins needed for the touchscreen, as well as the reset pin (tp_rst) and touch interrupt pin (tp_irq). The referenced nodes are configured in the corresponding Luckfox Pico model's.dtsifile. -
regconfigures the touchscreen's I2C device address. -
pinctrl/touchscreenconfigures thetp_rstandtp_irqpins. Ensure these pins are not reused for other functions or occupied by other drivers.
/* The pinctrl node creation has already been implemented in the dtsi file, so it is not needed in the dts */
touchscreen {
tp_rst:tp-rst {
rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>;
tp_irq:tp-irq {
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
3.2.8 USB Configuration
Luckfox Pico's USB is set to peripheral mode by default, allowing the USB to act as a device for ADB terminal access and as an RNDIS device for LAN access on the computer. When in peripheral mode, plugging in devices like a USB flash drive or keyboard will not have any effect. To configure the USB as host mode for recognizing attached peripherals, add the following to <Luckfox-pico SDK>/config/dts_config:
&usbdrd_dwc3 {
status = "okay";
dr_mode = "host";
&usbdrd_dwc3refers to the node that configures the USB mode. Other dependent USB nodes are enabled by default, with the source and default configuration found inrv1106.dtsiand the corresponding Luckfox Pico model's.dtsifile.- The
dr_modeattribute configures the USB mode. host represents host mode, and peripheral represents device mode.
3.2.9 CSI Configuration
Luckfox Pico's CSI is enabled by default. On Luckfox Pico / Mini / Plus / Pro / Max, you can control the CSI camera by simply inserting the CSI camera. On Luckfox Pico Ultra / Ultra W, since I2C4 also brings out other pin groups besides CSI, you need to modify the pinctrl-0 attribute of I2C4 to ensure the CSI interface works properly. To enable the CSI interface on Luckfox Pico Ultra, add the following to <Luckfox-pico SDK>/config/dts_config:
&csi2_dphy_hw {
status = "okay";
&i2c4 {
status = "okay";
clock-frequency = <400000>;
pinctrl-0 = <&i2c4m2_xfer>;
&csi2_dphy_hwrefers to the CSI2 D-PHY node, which is the underlying node for the CSI interface. If this node is not enabled, the property settings of other nodes will be ineffective.&i2c4refers to the I2C4 node. The sub-nodes related to the sensor are enabled in the corresponding.dtsifile, with support for the SC3336 sensor enabled by default.pinctrl-0is configured by default as<&i2c4m0_xfer &i2c4m1_xfer &i2c4m2_xfer>on Luckfox Pico Ultra to ensure complete device tree information in the final compiled DTB. This configuration in the.dtsfile will override the configuration in the.dtsifile to ensure the CSI is enabled correctly.
3.2.10 SDMMC Configuration
Luckfox Pico / Mini / Plus / Pro / Max have TF card slots with SDMMC enabled by default. If the system uses an SD card as the storage medium, disabling SDMMC could prevent the system from booting. Only Luckfox Pico Plus has the SDMMC pins exposed, and when Luckfox Pico Plus uses SPI-NAND as the storage medium, SDMMC can be disabled and the pins can be repurposed for other functions. The SDMMC configuration is already added by default in <Luckfox-pico SDK>/config/dts_config:
&sdmmc {
no-sdio;
no-mmc;
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
disable-wp;
status = "okay";
- To disable SDMMC, simply change the
