Cross Compiler
A cross compiler is a compilation tool that runs on a host platform (such as Ubuntu or a virtual machine) but generates executable files for a target platform (such as ARM or MIPS architectures). Since development boards have limited resources, Buildroot does not support compiling C programs locally by default, and a cross-compilation toolchain must be used.
Because the Ubuntu and Buildroot root file systems on the development board are based on different toolchains, users need to select the corresponding cross compiler on a Ubuntu 22.04 PC to ensure that the compiled programs run correctly on the target system.
1. Preparation Work
Obtain the cross-compilation toolchain:
Version Description Download glibc The cross-compilation toolchain for Ubuntu system needs to be obtained from ARM's official website corresponding to the cross-compiler Download uclibc The cross-compilation toolchain for Buildroot system can be obtained in the SDK Download Unzip the corresponding compressed package:
Ubuntu Execute the command:
#-C ~/ specifies the unzip path as the user's home directory
tar zxvf gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf.tar.gz -C ~/Buildroot Execute the command:
tar zxvf arm-rockchip830-linux-uclibcgnueabihf.tar.gz -C ~/
Take the program hello.c as an example to compile the corresponding executable file. The file execution effect is to print
hello worldon the terminal. The hello.c code is as follows:#include <stdio.h>
int main()
printf("hello world\n");
2. Compile to Generate Executable Files for Buildroot System
Choose one of Method One/Method Two to generate the corresponding files.
Method One: Modify Environment Variables
Set the environment variable for the cross-compilation tool. If you need it to take effect permanently, edit the configuration file (e.g.,
.bashrcor.profile).vim ~/.bashrcAdd the toolchain path, add the path of the cross-compilation tool to the system's PATH environment variable:
export PATH=/home/buildroot/luckfox-pico/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin:$PATH- Note: Please fill in according to your own SDK path
Update the environment variable, execute the following command to make the configuration take effect.
source ~/.bashrcUse the cross-compilation tool to compile the program.
arm-rockchip830-linux-uclibcgnueabihf-gcc hello.c -o helloFinally, transfer the executable file to the development board.
scp hello root@192.168.9.128:/root- Note: Please fill in according to the actual IP address of your development board
Method Two: Using Makefile
Create and edit the Makefile.
vi Makefile- Note: This Makefile needs to be created in the same directory as the hello.c file
Write the Makefile.
#Luckfox-pico-ultra-w-buildroot
CC := /home/buildroot/luckfox-pico/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf-gcc
hello:hello.c
-$(CC) $^ -o $@- Note: Please fill in according to your own SDK path
Execute the make command, and an executable file will be generated in the current directory.
makeFinally, transfer the executable file to the development board.
3. Compile to Generate Executable Files for Ubuntu System
Note:Choose one of Method One/Method Two to generate the corresponding files.Method One: Modify Environment Variables
export PATH=/home/ubuntu/luckfox-pico/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf/bin:$PATH- Note: Please fill in according to your own SDK path
arm-none-linux-gnueabihf-gcc hello.c -o helloFinally, transfer the executable file to the development board.
scp hello pico@192.168.9.128:/home/pico- Note: Please fill in according to the actual IP address of your development board
Write the Makefile.
#Luckfox-pico-ultra-w-ubuntu
CC := /home/ubuntu/luckfox-pico/gcc-arm-11.2-2022.02-x86_64-arm-none-linux-gnueabihf/bin/arm-none-linux-gnueabihf-gcc
hello:hello.c
4. Run the Executable File
- Execution in Buildroot:
- Execution in Ubuntu:
