WiFi
The Luckfox-Pico-Ultra-W is equipped with the AIC8800DC module, supporting the WiFi AX protocol (WiFi 6), and compatible with 2.4GHz WiFi and Bluetooth 5.2/BLE.
WiFi
Buildroot Connection WiFi
Edit the WiFi configuration file using
viornanoeditornano /etc/wpa_supplicant.conf
ap_scan=1
update_config=1
network={
ssid="luckfox"
psk="12345678"
key_mgmt=WPA-PSK
}ssid: Name of the wireless networkpsk: Password of the wireless networkModify according to your actual wireless network name and password. No need to change other settings.
If you want to switch WiFi networks, you need to restart the
wpa_supplicantservice:killall -9 wpa_supplicant
wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.confConnect to the wireless network.
udhcpc -i wlan0
Ubuntu Connection WiFi
viornanoeditorsudo su
ap_scan=1
update_config=1
network={
ssid="luckfox"
psk="12345678"
key_mgmt=WPA-PSK
You need to restart the development board
rebootConnect to the wireless network.
udhcpc -i wlan0
WiFi Speed Test
On the virtual machine or host
iperf3 -s -i 10 -p 5001-s: Specifies that iperf3 runs in server mode-i: Sets the report interval to 10 seconds-p: Specifies the server port as 5001
On the development board
iperf3 -c 192.168.10.176 -p 5001 -f m -i 2 -t 24-c:指定客户端模式,并设置要连接的服务器IP地址为192.168.10.176-p:指定服务器端口为5001-f:指定报告的格式。m代表 Mbps,即报告的带宽单位为兆比特每秒-i:指定报告的间隔时间为每1秒-t:指定测试的持续时间为30秒
Bluetooth
Buildroot
Due to certain dependencies of the BlueZ tools in Buildroot only supporting glibc and not ulibc, the tool cannot be used.
Setting ttyS1 as a Bluetooth HCI device:
# Older driver version
hciattach -s 115200 /dev/ttyS1 any 115200 flow nosleep&
# Newer driver version
hciattach -s 1500000 /dev/ttyS1 any 1500000 flow nosleep&Enabling hci0:
hciconfig hci0 upChecking Bluetooth status:
hciconfig -a
#蓝牙详细信息
hci0: Type: Primary Bus: UART
BD Address: 90:E4:68:A6:D6:94 ACL MTU: 1021:9 SCO MTU: 255:4
UP RUNNING
RX bytes:1344 acl:0 sco:0 events:77 errors:0
TX bytes:1217 acl:0 sco:0 commands:77 errors:0
Features: 0xbf 0xee 0xcd 0xfe 0xd8 0x3d 0x7b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV3
Link policy: RSWITCH SNIFF
Link mode: PERIPHERAL ACCEPT
Class: 0x000000
Service Classes: Unspecified
Device Class: Miscellaneous,
HCI Version: 5.2 (0xb) Revision: 0x14
LMP Version: 5.2 (0xb) Subversion: 0x14
Manufacturer: not assigned (2875)Scanning for Bluetooth devices:
hcitool scanBluetooth testing:
hcitool cmd xxxx
Ubuntu 22.04
Perform network time synchronization before installing or upgrading packages:
sudo su
ntpd -d
apt updateInstall Bluetooth-related tools:
apt install bluez
apt install pulseaudio-module-bluetoothStart the necessary services:
pulseaudio --startConnect a mobile phone to the development board:
bluetoothctl
power on # Enable the controller
discoverable on # Make the controller discoverable
pairable on # Set the controller as pairable
# When the phone searches for Bluetooth devices, "luckfox" will appear
# If a PIN code prompt appears, enter "yes"Additional
bluetoothctloperations:scan on # Scan for devices
scan off # Stop scanning
pair <MAC address> # Pair with a specific MAC address
paired-devices # List paired Bluetooth devices
connect <MAC address>
remove <MAC address> # Remove a paired device
