POE
Luckfox-PoE-Module is a Power over Ethernet (PoE) mini expansion board for Luckfox Pico Ultra/Ultra W, supporting the IEEE 802.3af network standard. To enable network connectivity and power for Luckfox Pico Ultra/Ultra W, a PoE router or switch supporting the IEEE 802.3af standard must be used, and the expansion board must be connected via an Ethernet cable.
Product Specifications
PoE Input Voltage: 37V ~ 57V DC
PoE Output Voltage: 5V 2.5A DC
Network Standard: 802.3af PoE
Product Dimensions: 50.00 × 34.80mm
Instructions for Use
Insert the PoE module into the Luckfox Pico Ultra/Ultra W.
Connect one end of the Ethernet cable to the PoE switch port, and the other end to the Luckfox Pico Ultra/Ultra W.
